Help please wrong oil??? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 01-14-2014, 10:06 PM Thread Starter
67 GTO's Avatar
Hey guys so end of the summer I changed the oil on my 67 Pontiac 400, I used a Castrol 10w-30. Ran it for a bit, did some short drives with it not much running. Now it sounds like there Is a slight tap. Could this be from the oil? There was a heavier weight oil in it previously. I am changing the oil again and putting a heavy weight back in. But did I do any damage? Any ideas or comments welcome
Thank you in advance
67 GTO is offline
post #2 of 9 (permalink) Old 01-15-2014, 07:12 AM
Doubt you did any damage with what you described here. I recommend Brad Penn 10w30. Matt
Matthew is offline
post #3 of 9 (permalink) Old 01-15-2014, 10:23 AM
Quoted: 118 Post(s)
What Matt said. Castrol doesn't have the ZDDP you need for cam protection. I seriously doubt you got a flat cam due to the stock configuration of your engine and limited and easy use it gets. More than likely a hydraulic lifter that is bleeding down. Use a good oil like Brad Penn or use what you want with ZDDP additive.
post #4 of 9 (permalink) Old 01-15-2014, 10:36 AM
Also it's possible that the heavier oil was masking a problem that was already there. That's an old "dishonest used car dealer trick": put really heavy/thick oil into an engine that's making some noise and it'll quiet it right down, usually just long enough to get the car sold and off the lot.
post #5 of 9 (permalink) Old 01-15-2014, 01:04 PM
.............or try a 4oz bottle of ZDD and see if it stops.
post #6 of 9 (permalink) Old 01-15-2014, 03:36 PM Thread Starter
67 GTO's Avatar
Thank you guys!! made me feel a lot better, I changed the oil and added that and we shall see what happens comes spring time!!!
67 GTO is offline
post #7 of 9 (permalink) Old 01-16-2014, 07:13 AM
Before my motor was gone over and it leaked I used Valvoline 50W racing oil with ZDD in it. I then looked for 30 or 40W couldn't find it then I did find 30W Valvoline racing oil with ZDD at a garage they can order it..... My plan was to finish my stock of ZDD but I keep finding it on sale and buying a couple here and there. I have enough for a few years yet and I would imagine I will see it on sale again low enough to buy a few more.
post #8 of 9 (permalink) Old 01-16-2014, 12:01 PM
Quoted: 118 Post(s)
I would not use racing oil in a street engine. It does not have the additive package you need on the street for engine protection. It is meant to be dumped out after each event and does not have the anti-corrosion properties you need in a street driven engine where the oil is in the pan for a few months (or more) at a time.
post #9 of 9 (permalink) Old 01-16-2014, 12:45 PM
I didn't use the track oil I used this it helped slow the leak in conjunction with Bars leak. the leak got worse.... when I dove into it..... it was a disintegrated oil pan gasket and it was shooting oil in the area of the rear main seal giving the illusion it was the seal but it wasn't. With the engine laid open the inside was immaculate.
Valvoline VR1 20W-50 Racing Conventional Motor Oil (1 Quart) VV211: Search no more for the best Racing Motor Oil at Advance Auto Parts
What's wrong here ? bondobill 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 11-07-2012 12:18 AM
wrong driveshaft! help... yousaygo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 08-12-2011 12:28 PM
Something's wrong with my LS2. batmans Engine Discussions 209 09-03-2010 01:49 PM
what else could go wrong gtogooch Engine Discussions 0 02-04-2010 08:03 PM
What the hell am i doing wrong?!?!?! GTO19020 Racing and Kill Forum 6 10-26-2009 07:12 PM
