Hi Torque Starters - Pontiac GTO Forum
post #1 of 11 (permalink) Old 05-16-2012, 08:43 AM Thread Starter
Hi Torque Starters
Anyone ever used the PowerMaster 3555 Hi Torque Starter or the TCI 369600 Hi Torque Starter? Thinking about purchasing one or the other for my 455. The PowerMaster is the least expensive of the two. Some folks have said to use the Mini Starter but I dont know if that is necessary. Thanks
timmyg is offline
post #2 of 11 (permalink) Old 05-16-2012, 09:07 AM
I'm running a RobbMc myself and I love it.
post #3 of 11 (permalink) Old 05-16-2012, 09:16 AM
Quoted: 98 Post(s)
I've never found it necessary to run anything but the GM starters in any of mine....but mine aren't stroked out monster motors. If the starter, solenoid, wiring, and connections are all up to snuff, they work fine. A lot of times, folks will install a magic bullet starter to help band-aid a weak electrical system. The real benefit for the smaller, high torque starters in my opinion is increased header clearance and weight savings.
post #4 of 11 (permalink) Old 05-16-2012, 09:20 AM
Ayep... that's why I went with the RobbMc - clearance, that and the fact that it's "clockable" -- I've got it rotated so that the solenoid is "down" and as far away from the header as I can get it. It's fairly easy to install/remove with the header on. I'm not so sure a factory starter would be so.
post #5 of 11 (permalink) Old 05-16-2012, 11:55 AM
I've been thinking of getting a mini also due to my hot start problem.
400/400
10 Bolt w/3:55 posi
Expresso Brown w/Gold Interior
jimchevy is offline
post #6 of 11 (permalink) Old 05-16-2012, 01:41 PM
Quoted: 98 Post(s)
Factory starters and headers don't get along, I agree. To be able to clock the starter to keep the solenoid well away from the exhaust heat is an added bonus. There are no mounting options with the oem unit....a disadvantage when running speed equipment!!
post #7 of 11 (permalink) Old 05-16-2012, 02:55 PM
Has anyone tried the " hot shot " or relocating the noid? I have a mini starter on my 455 with coated headers and still get hot start problems. I'm also interested in learning more about the clockable starters.
Scott
Thejudge 69GTO is offline
post #8 of 11 (permalink) Old 05-16-2012, 04:14 PM
rickm's Avatar
Quoted: 5 Post(s)
gear reduction is the key to (mini starters) besides the benefits already mentioned. a high torque gm stock style starter even with solonoid heat shield , with headers on a sizzlin hot afternoon = starting problems. rickm.
rickm is offline
post #9 of 11 (permalink) Old 05-16-2012, 08:38 PM
Originally Posted by Thejudge 69GTO View Post
...I'm also interested in learning more about the clockable starters.
Scott
This is the one I have:
RobbMc Performance Products - Pontiac Starter
There are some long bolts that clamp the body, including the solenoid, to the end-plate that bolts to the engine block. You can loosen the bolts and rotate the body of the starter and solenoid to any position you want. You can even do it with the starter installed.
I've got nearly every product they make on the Beast, and I can tell you first hand that their stuff is very high quality, and they're more than fair in working with you if you have a problem. I caused a problem with the starter myself. I had it installed "too tight" to the engine, it needed to be shimmed out a little. That eventually caused the pinion gear on the starter to grenade. I sent it in for repair after it happened, after figuring out what I'd done wrong. Even though it was both out of warranty and my fault, they fixed it for me at no charge.
Class act, they are.
post #10 of 11 (permalink) Old 05-16-2012, 09:02 PM
Quoted: 23 Post(s)
I have a powermaster and love it, also clockable, spins the 463 without hesitation even when hot...and yes with headers ever little bit of clearance helps. I picked it up for 20.00 at a swap meet and took to the local electrical shop and the old timer re-built it for me in a day and tested it out right in front of me for 60.00. have had bad units out of the box from the auto parts so i will take my local tradesman all of my business from now on.
Instg8ter is offline
Torque settings jcgclu Intake and Exhaust Discussions 1 01-01-2009 04:44 PM
torque converter jradke123 Racing and Kill Forum 7 06-20-2008 07:59 AM
horsepower vs. torque banshee 2004-2006 GTO General Discussion 6 05-28-2007 03:01 PM
Remote Starters RipTheSix The Lounge 0 12-06-2006 10:14 PM
Remote starters... criminally_sane Interior Discussions 6 11-30-2006 07:50 PM
