Hideaway headlight don't open/close at the same time - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-03-2019, 11:33 AM Thread Starter
Hello,
I have a 68 gto with the hideaways. All new lines and actuators. Original headlight switch. When I pull out the headlight switch to turn on the headlights one side opens completely then the other side opens completely. When I push the switch back in, one side closes then the other. I have switched lines and actuators but the same thing happens.
It seems that there isn't enough vacuum to do both at once. Any thoughts or help appreciated.
Thanks, Tony
gtony67 is offline
post #2 of 5 (permalink) Old 05-03-2019, 08:39 PM
Quoted: 401 Post(s)
Originally Posted by gtony67 View Post
Hello,
Thanks, Tony
No expert on this at all, but I have seen the drawings of the system. It has a vacuum tank/cannister. You may be missing this?
The other things to check would be any binding and make sure you have all the springs installed in the correct manner. Here is a website that has both the vacuum line diagram and mechanical parts of the system. Just click on them to open the PDF. Delaware Valley Old Goat Club
post #3 of 5 (permalink) Old 05-04-2019, 09:59 AM Thread Starter
Thanks, I have the canister. Doesn't seem to be any binding. I'll look for a leak somewhere. They work but not at the same time.
gtony67 is offline
post #4 of 5 (permalink) Old 05-05-2019, 12:02 AM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
I would look for a restriction in one of the hoses on the slow side.... maybe even a vacuum gauge
plugged into the end of the slow actuator hoses ....
pull the slow hose apart at the plastic splitters...
make sure the holes are nice n open in the fitting
look for a pinched hose on the slow side ... blow it out with compressed air ?
is your over center spring adjusted too tight ?
compare vacuum readings from fast one to slow one ...
swap the actuators side to side ..
un hook the lever arm to the hieaway and run just the actuators by them selves and check them for timing
Scott
then go for a drive to get fuel because it just idled for 1/2 an hour while you were testing
BLK69JUDGE is online now
post #5 of 5 (permalink) Old 05-05-2019, 12:58 PM Thread Starter
Thanks for the info. Good stuff! I'll check that out.
gtony67 is offline
1968 GTO Hide away head lite don't close rob40999 Engine Discussions 3 06-21-2018 04:58 PM
Are the headlight bezels the SAME for both a 1970 GTO & LeMans? azmusclecar 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-18-2014 10:42 AM
Hideaway Headlight Actuators 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 04-25-2011 08:42 AM
68 headlights open when car is running, won't close AzStateFan 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-14-2009 11:03 PM
hideaway headlight question 1969gto 1964-1974 Tempest, Lemans & GTO General Discussion 17 12-20-2005 10:54 AM
