Hood adjustment tips anyone? - Pontiac GTO Forum
post #1 of 14 (permalink) Old 09-06-2011, 10:14 PM Thread Starter
gotyorgoat's Avatar
Does anyone have any tips on getting the hood and fender panels to align?
My hood is 3/4" high on the rear drivers corner and does not want to sit down. The other side fits fine and I see no difference between the two hinges. Should I slot the mounting holes in the hinge so I can move the whole hinge down? I don't see any way possible to shim the surrounding panels up 3/4" and it does not seem like the hood is warped at all.
Any general knowledge or tips of the trade would be appreciated.
gotyorgoat is offline
post #2 of 14 (permalink) Old 09-07-2011, 07:07 AM
Unless one has experience with this it is a tedious trial and error job with 3 or 4 people. 2 on each side adjusting bolts one in the front watching alignments. Took me "forever" to get it close. Side to side then front to back. Lots of opening and closing the hood.
post #3 of 14 (permalink) Old 09-07-2011, 07:24 AM
Loosen the hinge to fender bolts, have someone lift the front of the hood as far as it will go, tighten the hinge to fender bolts, close hood slowly to check for clearance.
post #4 of 14 (permalink) Old 09-07-2011, 08:02 AM
Do you have hood bumpers on your cowl? If so, check the one on the left side for clearance -- adjust it down.
Matthew is offline
post #5 of 14 (permalink) Old 09-07-2011, 08:46 AM
And another thought... assuming your hinge is adjusted down, is your hood being held up on the left corner by a hood to fender bumper? Small rubber wedge like bumper on the upper lip of the fender. If so, you may not have enough space between your hood and left fender.
Also, how's the alignment at the front of the hood? High left low right will cause your hood to be high at the left rear. If that is the case, you would adjust your right front hood bumper up and the left front hood bumper down.
Matthew is offline
post #6 of 14 (permalink) Old 09-07-2011, 08:54 AM
66tempestGT's Avatar
several people here have got good results from doing it rukees way.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #7 of 14 (permalink) Old 09-07-2011, 10:40 AM
Something that worked for me in a similar situation was to lower only the rear half of the hinge, tilting it a little more towards the rear of the car. As others have said, work very carefully and very slowly after you've changed something. Lower the hood a little bit at a time, checking all the clearances and gaps as you go. 'Slamming' a hood that's off just enough to catch on an edge can very quickly ruin both the hood and the paint job.
post #8 of 14 (permalink) Old 09-07-2011, 12:43 PM
And your day. Thats why I don't run a hood OP. JK ( I've got 3! )
post #9 of 14 (permalink) Old 09-07-2011, 02:33 PM Thread Starter
gotyorgoat's Avatar
Thanks for the input. I did loosen the bolts, opened the hood all the way (forcing the hinge down) and retightened with no success, but i will keep messing with it to see if I can make it look better. I do not have any hood bumpers on the cowl, but there are the wedge shaped ones against the fenders. I'll check for clearances. Paint is rough so I'm not real worried about chips, but I would never slam the hood on my baby anyway. 50% of the time, she starts every time.
post #10 of 14 (permalink) Old 09-07-2011, 03:07 PM
I smell a new sig quote!
66' door adjustment... Instg8ter 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 8 03-14-2011 09:59 PM
Rocker arm adjustment ozboz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 01-26-2011 06:35 AM
Dwell adjustment BobG 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-06-2007 08:20 PM
04 GTO Audio Adjustment ThePrincipal Test Forum 3 01-03-2006 11:32 AM
headlight adjustment HoldenGTO Service, Maintenance and Technical Discussion 7 12-21-2005 07:02 AM
