How many lbs of R 12 - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-20-2011, 03:30 PM Thread Starter
In my 68 GTO with factory air, from a vacuum about how many lbs of R 12 does the system hold??
dimitri is offline
post #2 of 6 (permalink) Old 01-20-2011, 05:24 PM
My 69 Factory Service Manual says 4 1/8 pounds (if you're filling by weight from a large drum) or 4 1/3 cans (if you're filling from individual disposable cans of R-12) plus 11 ozs. of oil. I've also got oil re-fill specs for any individual components you may have replaced if you need that. If you haven't replaced anything, then you shouldn't need to add any oil.
post #3 of 6 (permalink) Old 01-20-2011, 06:27 PM
There "should' be a sticker on the compressor. It says how many lbs the system holds.....
Eric Animal is offline
post #4 of 6 (permalink) Old 01-20-2011, 07:05 PM Thread Starter
Thanks Guys,
My sticker only says how much oil for the compressor.
dimitri is offline
post #5 of 6 (permalink) Old 01-21-2011, 08:28 AM
According to the 67 Service manual....3 3/4 lbs for Tempest series. 4 1/8 lbs for fullsize Pontiacs. That is after evacuating the system and vacuuming it down.
post #6 of 6 (permalink) Old 01-21-2011, 11:37 AM Thread Starter
Thanks again.
dimitri is offline
Back strip with 22 lbs boost forensicsteve Audio & Video Clips 3 11-02-2008 04:22 PM
Back to track on 16 lbs forensicsteve Audio & Video Clips 12 04-28-2008 02:52 PM
443hp, 440ft-lbs GTO_400 Service, Maintenance and Technical Discussion 10 11-17-2005 02:29 PM
shedding some lbs mc364 2004-2006 GTO General Discussion 3 11-14-2004 10:42 AM
