How to replace rear cross member? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 02-23-2016, 12:20 PM Thread Starter
EdR
Hi.. I'm replacing my rear bumper on my 69 GTO and noticed the rear cross member is pretty well rusted and the rear body mounts are cracked and fairly well shot. I'm thinking I should replace the cross member and body mounts while I'm at it but don't want to open a huge can of worms. It doesn't look like I can get at the top of the body mount bolts without cutting into the trunk pan. Anyone have experience replacing the rear cross member they can share?
EdR is offline
post #2 of 3 (permalink) Old 02-23-2016, 04:20 PM
the furthest rear frame crossmember is often bent, some are badly rust pocked. Have zipped quite a few out of parts car frames with a sawsall. then carefully trimmed the old rear crossmember out and MIG welded it onto the frame. Welding can be performed with the body on the frame. rear bumper will have to come off, rear body bolts removed, along with gas tank.
post #3 of 3 (permalink) Old 02-23-2016, 05:03 PM Thread Starter
EdR
thanks.. sounds like more than I want to take on right now. The one I have is rusted, but its basically in tact and not bent. I might just wire brush it and coat it with POR 15. Although I would like to replace the body mounts. I'm just concerned if the bolts break or top nut breaks free I'm in for a whole other project cutting into the trunk Pan and then having to repair that. You ever have problems taking out the body mount bolts?
EdR is offline
transmission cross member tspring 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 03-11-2015 03:20 PM
Motor sitting on Cross Member USArmy1993 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 05-10-2012 01:22 PM
04 Rear Diff Replace amdoverclocker Drive train, suspension, alignment and brakes. 9 01-11-2012 06:33 AM
Replace the rear wing mike9128 2004-2006 GTO General Discussion 1 07-15-2006 05:37 PM
Rear seal replace gman26 1964-1974 Tempest, Lemans & GTO General Discussion 3 01-22-2006 12:30 AM
