I need help deciding. When is it "restored"? - Pontiac GTO Forum
post #1 of 16 (permalink) Old 10-02-2013, 06:37 PM Thread Starter
skurfan's Avatar
I have been on this forum about a year now. I bought a survivor '67 GTO from a guy and got it mechanically sound. I drive it several times a week. It looks decent but the body lower panels have some rust. I have taken it to three different restoration/paint shops here in my area and the estimates to paint it are 10-12k. I also have bought two rust free quarter panels. If I go thru with this project, it will get quarters cut and the "new" ones put on. It will also get a new tail panel. I don't really mind the original paint but something needs to be done on the bottoms and all the trim is not on the car. There are also a few spots where the original owner hit with grey primer. I would only consider painting the car Cameo Ivory which is the original color. The interior is red and in excellent condition. So....my question.....when is it considered "restored" and no longer original? Value wise, am I better off where I am at now, and even if I would fix the lower panels I am not sure if it would look right with new paint in some areas. After seeing those rust buckets sell for big money in Pierce, Nebr. I have been pondering this. I would hate to ruin a piece of original history because it's only original once. If you are still reading this and awake, I would appreciate any input.
skurfan is offline
post #2 of 16 (permalink) Old 10-02-2013, 08:57 PM
I say fix the rust and paint it.
And maybe consider painting it yourself or having a local tech school do the work. Sounds crazy huh? Well when I did my Riviera and a truck for my niece the local tech school did the work and it came out outstanding. They stripped the car to bare metal and metal worked out all the dings. Paint jobs both came out excellent as the teacher had the best students do the paintwork and they had all the latest and best equipment. Cost to me? Materials only and I bought them all pizzas and a cooler full of soda's for a job well done.
Paint it yourself? Well, you could take that tech school class yourself and do it at school or for the money involved buy a compressor, paint guns, welder and suplies and still have money left over plus you'll still have all the stuff when the car is done not to mention the skills you will learn. That's what I did and several other members on here including BearGFR (who did a black GTO btw!) And Instig8tor who's car also looks awsome. You can do it. The only real factors are if you have the time and room. And I've also seen and heard many nightmare stories of owners who have had their cars in "paint jail" for extended periods of time and shelled out mucho $$$$ and had less than stellar results. Be sure to get references from previous customers before entrusting a body shop with your pride and joy.
And as far as "restored" I believe that when you do a car restoration you are really restoring several things....suspension, interior, exterior, trunk, chrome and on and on. When i did my car that is how i treated my project; as several "smaller" projects and that make it easier on me and not so overwhelming.
post #3 of 16 (permalink) Old 10-03-2013, 09:01 AM
chuckha62's Avatar
Quoted: 18 Post(s)
Whatever you end up calling it (restored, repainted, repaired...) is immaterial. When it's done, it will be better (i.e. worth more) than a "survivor" with rusted quarter panels.
Now, do the quarter panels need replacing, or just the lower areas behind the wheels? If it's just the drop offs, then I wouldn't be inclined to replace the entire quarter panel. If that's the case, you can do it yourself. The cost of materials and tools will be less than paying someone to do it and you'll have the tools when you're done.
I replaced both lower drop offs on my '63 Nova SS and they turned out great, inside and out.
Chuck
chuckha62 is offline
post #4 of 16 (permalink) Old 10-03-2013, 10:24 AM
I'd say repair it, but only replace the rusted section, not the whole quarter if possible. I did the bottom sections of mine and was able to keep it low enough were you can't see it from inside the trunk.
post #5 of 16 (permalink) Old 10-03-2013, 11:39 AM
Quoted: 105 Post(s)
I'd repair and repaint it. Restored means back to as new, factory condition. With rust out, the whole 'survivor' thing is off the table. Fix and enjoy.
post #6 of 16 (permalink) Old 10-03-2013, 05:59 PM
Quoted: 23 Post(s)
with Alky, if you have a local HS that has body shop classes they will do it for material costs (technically cannot charge for labor). They were nice enough to rent me their brand new booth for the day and let me use a brand new 600 dollar Iwata gun and all the masking materials for a few hundred dollars, which by the way went to support the school car club which these days do not receive any funding from feds or state. The kids were all over the Tempest when i hauled it up on Friday to drop off for spraying on Saturday, a few even stayed after school to help me push it in and mask it. If you want it to look original and keep cost down spray back in enamel single stage. Cameo white will blend and over spray easier than darks or metallics and any runs or oops's can be sanded and buffed out, plus you get to say ...I did it all myself!! The paint on these cars was not flawless from the factory.
If most of the original paint is good DO NOT, sand it off to bare metal. Degrease it scuff it with a scotch bright pad and prime the original with epoxy and blend in your repairs. The only spots i had minor paint problems were the ones where i took it down to metal and and broke the seal of the original paint and primer to metal bond.
Instg8ter is online now
post #7 of 16 (permalink) Old 10-03-2013, 09:22 PM
^ You can't argue with those results.
With taking a car to bare metal, prep and cleanliness and use of compatable products is a must for satisfactory results. Any moisture or contamination will lead to problems down the line. And I also agree with not replacing any more of the sheetmetal that is rotted than necessary.
post #8 of 16 (permalink) Old 10-04-2013, 06:58 PM Thread Starter
skurfan's Avatar
Thanks for all the good advice. Instig8tor, your car is beautiful.
skurfan is offline
post #9 of 16 (permalink) Old 10-04-2013, 07:05 PM
Quoted: 23 Post(s)
Thanks Skurfan, don't be afraid to try the repairs yourself...is the 12-15 quote with bodywork or just for paint?
I had not wrenched on my own cars for 20 years when i took the Tempest on. and when i seen the price of what people were saying paint cost i thought i might never get my car done if i had to shell out that kinda scratch in one lump. Materials for good BC/CC sytems will run you around a grand, if you go Enamel single stage probably half that. the spraying is really 10% of the work, getting the body flat and straight is the 90%.
post #10 of 16 (permalink) Old 10-05-2013, 05:25 PM Thread Starter
skurfan's Avatar
I may try it myself. Considering taking a welding class at the local CC here. I am sure I can handle the rest. Been practicing on a couple lesser cars and watching and reading a lot. The 12k estimate was for the whole thing. It's guys that are considered top quality in these parts and you pretty much just give them your credit card and car and they seem to hold it hostage until they get all you got. Not my idea of a good deal for me.
skurfan is offline
"Import-lover returns...with alarming news!!"...details inside! Zulu Member Introductions 4 07-16-2012 09:53 PM
K&N aftermarket cai keeps thowing "IAT" codes wtf gmForever82 Intake and Exhaust Discussions 2 08-16-2011 07:25 AM
Spare "tire"..better check it. "my lucky day" JWCACE Wheels and tires 0 05-17-2006 09:32 AM
Meineke "glasspacks" installed on '04... GREAT sound, dirt cheap Stephen Hopkins Intake and Exhaust Discussions 0 03-27-2006 12:50 PM
