I ordered new rims for my '67 GTO tonight! - Pontiac GTO Forum
post #1 of 23 (permalink) Old 03-15-2013, 12:39 AM Thread Starter
I kept going back and forth between the Year One Rallye II's or the US Mags Bandits, and I went with the Bandits. I went with 17 X 8 and 17 X 9's. I am going to build this car for to handle, brake, and drive well, but I'm keeping a ride height and small enough brakes to still bolt up 15" tires and look stock when I want to. It is an advantage that these cars sat low from the factory. I have a set of 15" Rallye II's, but I may get a set of steelies and paint them when I paint the car and get a set of repro poverty caps and a set of Coker Red Lines to put on the car to go shows, etc. My goal is toi build a stock appearing car on the body, interior, and under the hood that doesn't handle and brake like a 46 year old car.
These are the rims I ordered. I'm going to put a Pontiac cap on them and use red center lug nuts to help make the red fender liners pop a little. I'll be waiting a kid for Christmas to come until they get here! -lol
Name:	us mags bandit.jpg
'67 GTO 400 H.O. - 4 speed - 3.55 posi
67GTO4SPD is offline
post #2 of 23 (permalink) Old 03-15-2013, 12:41 AM Thread Starter
Here's a closer look of someone else's wheels off of another forum. He just got his in today.
Name:	us mags u109.jpg
post #3 of 23 (permalink) Old 03-15-2013, 05:32 AM
Those will look awsome on a 67, I especially like your ideas for the red accents. What color do you plan on painting the car?
post #4 of 23 (permalink) Old 03-15-2013, 05:01 PM Thread Starter
It is a factory black car with red interior, but the PO put a new PUI interior kit it in. I am going back with red eventually, but for now its going to be black on black with a splash of red from the fender liners, center caps, and lug nuts.
post #5 of 23 (permalink) Old 03-15-2013, 05:07 PM
jmt455's Avatar
That's going to be a good looking car!
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #6 of 23 (permalink) Old 03-15-2013, 09:28 PM
67GTOCoupe's Avatar
What do you plan on doing brake wise as an upgrade? If I remember correctly the 64-67 GM A body control arms will accect the spindle from the GM F body cars right up to 81 for an inexpensive disc brake upgrade. The only part you actually need to buy is the rubber flex hose because the threads on the car side do not match up. Other than that they go right in and stock rotors and pads for those cars a dirt cheap. Oh and I almost forgot you need to change the bias valve also to get more juice to the front discs to allow the car to take advantage of the more powerfull discs.
Best off all the modification can be undone to!
I did it on my 64 Olds 442 many moons ago
67GTOCoupe is offline
post #7 of 23 (permalink) Old 03-15-2013, 11:25 PM Thread Starter
I'm not sure yet. I have a set of GM A-Body discs for the front, but I may buy a 4 wheel disc brake set-up. I've seen complete kits that will still fit a 15" rim for the front and rear for around $800. I want to still be able to put a 15" rim on the car when I want to. I may go that route.
post #8 of 23 (permalink) Old 03-16-2013, 04:04 PM
Black with a red interior......NICE WHEELS !
ID:	17177   Click image for larger version
Eric Animal is offline
post #9 of 23 (permalink) Old 03-19-2013, 10:58 PM Thread Starter
Can't go wrong with that color combo.
post #10 of 23 (permalink) Old 03-20-2013, 11:53 PM
I didn't think 9" would fit the rear of 66 and 67???
Harvey
GS-XNR is offline
ordered 295-60d-15 hoosier rear tires for my 1969 gto 1969gtojohn 1964-1974 Tempest, Lemans & GTO General Discussion 4 07-04-2009 04:55 PM
Just Ordered A 2006 GTO Need Advice 2006GTO Service, Maintenance and Technical Discussion 28 12-13-2005 04:23 AM
Couple of GTO's running at Gainesville tonight... Joecooool 2004-2006 GTO General Discussion 5 05-19-2005 10:29 AM
Locating An Ordered Gto GTO JUDGE 2004-2006 GTO General Discussion 0 05-13-2005 07:30 PM
