If It Ain't Broke.... - Pontiac GTO Forum
 5Likes
  • 1 Post By PontiacJim
  • 1 Post By Lemans guy
  • 1 Post By Frankz28
  • 2 Post By Lemans guy
post #1 of 5 (permalink) Old 07-22-2017, 04:27 PM Thread Starter
Just bought a new ride. 1972 Convertible which was running great. Had purchased a Sears Engine Analyzer months ago at a garage sale. Hey I have a great idea lets see if this thing works. Worked fine. I didn't get beat for the $10. Unclipped the coil lead and a wire broke at the coil. Negative side. Spliced in less than 3 inches of wire put a new end on it and hooked it back up. Ran for two seconds and stalled. For two days now it just cranks. No Start. Cleaned and reset the points. Removed cleaned coil and the leads. Still just cranks. What am I missing? Car has a after market hood tach. (Doesn't and didn't work before) Fuse, Fusible-link, Wiring Diagram for a coil? Trouble shooting flow chart? Thanks for looking and thanks in advance for any help.
Frankz28 is offline
post #2 of 5 (permalink) Old 07-22-2017, 06:13 PM
Quoted: 391 Post(s)
You need spark & gas to get it to run. Confirm you have spark at the plug. If no spark, then you can begin your ignition checks. If you have spark, then you need gas. Pour a small cap full of gas down the carb and see if it will start. If it starts or runs, it is a fuel problem.
Start with the spark at the plug first. You might also want to use the RED "SEARCH" feature found in the upper right of the page. Type in "engine will not run" and see what pulls up. You may get a few leads on what to check for.
Bobbyg likes this.
post #3 of 5 (permalink) Old 07-23-2017, 08:24 AM
Lemans guy's Avatar
Quoted: 70 Post(s)
The negative coil wire goes to the distributor and points, when you spliced in the 3 inches of wire is the new wire of the same gauge? you can add wire that has too much resistance and you then interrupt the flow of electricity.
Make sure it is the same gauge, and then test your splice with an ohm -meter or test light, connections can be bad as crimped connectors are not always reliable, crimped and soldered is correct.
If that is all right follow,..... Pontiac Jim's advice. Gas and spark.
PS on any no start condition I always put gas in the tank a few gallons if you can, rather than go by the sending gauge could be wrong or even thinking you filled it as pump at station kept clicking off,....vapors do that as well.
sounds like you added resistance to the negative coil wire and dropped that already ballasted wire from 9 volts to like 6 volts and it won't fire
Bredfan likes this.
Lemans guy is offline
post #4 of 5 (permalink) Old 07-23-2017, 02:25 PM Thread Starter
I never would have thought I was out of gas.
Thanks Pontiac Jim & LeMans Guy
Bredfan likes this.
Frankz28 is offline
post #5 of 5 (permalink) Old 07-24-2017, 10:13 AM
Lemans guy's Avatar
Quoted: 70 Post(s)
EZ fixes are good fixes!
1968gto421 and Bredfan like this.
Is it is, or is it ain't a 65 goat? wishihaditback 1964-1974 Tempest, Lemans & GTO General Discussion 3 07-11-2014 04:20 PM
Gto ain't turning on Eddie05 Interior Discussions 2 03-14-2011 10:16 AM
Gto ain't turning on Eddie05 Service, Maintenance and Technical Discussion 0 03-12-2011 04:28 PM
Jiffy ain't Luben' PEARL JAM The Lounge 6 08-09-2007 08:09 PM
Ain't Gonna Buy No POS Furrin Veehickles Wing_Nut The Lounge 18 04-06-2007 05:28 PM
