If I wanted a block... - Pontiac GTO Forum
 2Likes
post #1 of 12 (permalink) Old 03-06-2019, 11:54 AM Thread Starter
Anderslober's Avatar
Quoted: 24 Post(s)
Hello forum......just a qq...I am looking around for a 400cui block.....only problem is that I am in Denmark.!
where would I find a rebuildable 400cui? Please recommend some breakers in the US that I can contact..........
If the breakers ship..fine. Otherwise I have a friend in the US who can help me...
There should be a sticky thread where all good Pontiac breakers are listed..........is there? I havent yet checked the whole forum...
Thanks again....
Anderslober is offline
post #2 of 12 (permalink) Old 03-06-2019, 11:57 AM
the65gto's Avatar
Quoted: 12 Post(s)
Just to clarify....what are "breakers"? We might call them "Junk Yards" here? You could look here. http://www.lenwilliamsautomachine.com/Home.html some options there.
the65gto is online now
post #3 of 12 (permalink) Old 03-06-2019, 02:33 PM Thread Starter
Quoted: 24 Post(s)
Yes...of course....junk yards.......
I will check your link...thanks....
post #4 of 12 (permalink) Old 03-06-2019, 07:27 PM
Quoted: 404 Post(s)
Thanks again....
I think it would be safer to have your friend try to locate a block. Once he does, then have it taken to a machine shop were they can evaluate the block by hot tanking & cleaning, magnafluxing to check for cracks, sonic test the cylinder walls for thickness, check bore size and roundness, check the deck for warpage, etc.. If all passes, then have it shipped.
These blocks/engines are now old and pretty worn out as many have already been rebuilt a time or two. Finding one in a junkyard is not easy as few junkyard have old cars anymore, so you will most likely find a block or engine in a "classified advertisement" in a local paper, car show/swap meet, or the popular "Craigslist" that would be in your buddies area. You don't want a block that has rotted away on the inside but looks good on the outside. There are those who would sell you a block and tell you it is good, but when you receive it over there in Denmark, it may be bad.......and what are you going to do about it?
You want a block that is 1974 and earlier as later blocks have thinner castings and will not hold up under higher horsepower. Engine block mounts can be different and some will not drop in without engine mount changes. So you want to be aware of this.
As suggested, to save you a lot of problems, you might want to consider purchasing an engine block from a reputable Pontiac engine machine shop/builder. They would not sell you a bad block. Might cost you more to do this, but if you get a bad block shipped to you, how many times do you want to take a chance and do it again hoping the next block is good?
post #5 of 12 (permalink) Old 03-06-2019, 08:44 PM
I don’t know what your schedule is on your build or where your friend is located, but I have a 400 motor that’s actually in a car and running right now. I will be changing the motor over next winter. So this is a block that your friend can actually see and here run while it’s still in the car. PM me if you’re interested and I’ll give you all the info. I’m just outside Chicago.
Bill E is offline
post #6 of 12 (permalink) Old 03-06-2019, 10:26 PM
Lemans guy's Avatar
Quoted: 79 Post(s)
Also talk to Butler Performance Pontiac Group in Lawrenceburg, Tennessee south of Nashville Tn.
Butler has period 400 blocks sitting on their shelves and they ship to Europe. They do all the testing Pontiac Jim outlines, or can build the short block for you or any stage you want.
They are very helpful, give them a call and Check their website...Butler Performance.com.........phone.......866-762-7527
I have no relation with them other than they supplied and race prepped my short block. I have been to their shop many times for parts and they are a small family operation, ........some are great at Pontiacs, ......but nobody is better than Butler Performance.
Whatever you decide Good Luck!
1968gto421 likes this.
Lemans guy is offline
post #7 of 12 (permalink) Old 03-07-2019, 09:02 AM Thread Starter
Quoted: 24 Post(s)
Wow!...thanks for all that excellent info. I am on the case.......
I was hoping for a 68/69 block......
post #8 of 12 (permalink) Old 03-07-2019, 12:50 PM
Quoted: 119 Post(s)
Put an ad in the 'parts wanted' section on this forum, and also on the Performance Years/Ames forum. That one gets a LOT of visits from a bunch of people. You should easily be able to get the engine you want. Good luck.
Jeff
post #9 of 12 (permalink) Old 03-07-2019, 10:51 PM
Quoted: 31 Post(s)
Thanks again....
As suggested, to save you a lot of problems, you might want to consider purchasing an engine block from a reputable Pontiac engine machine shop/builder. They would not sell you a bad block. Might cost you more to do this, but if you get a bad block shipped to you, how many times do you want to take a chance and do it again hoping the next block is good? [IMG class=inlineimg]https://www.gtoforum.com/images/smilies/thumbsup.gif[/IMG]
You can buy a great block after 1974. Pontiac went back to old casting in 76/79 I think, just stay away from 500557 blocks if your looking for high hp or stroking . If not it s good block cheap that most sell cheap. , plenty of standard bore 400 out there just keep eye on Craigslist . Doug
dd68gto is offline
post #10 of 12 (permalink) Old 03-13-2019, 09:42 PM
I have a 400 block from a 1970 Ram Air III. The block/crank have been machined. Bored .040 over. I have decided to put an LS in the car since the motor is not original (I have a 66 GTO). I would be willing to ship to you. PM me and I can send you some pics if you're interested
Bobbyg likes this.
Here_knor_there is offline
If you wanted to add A/C to a 66 GTO... speedracer25f 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 08-11-2012 12:33 PM
Actual differences between and RA block and non RA block DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-26-2010 01:07 PM
326 block and 400 block jbranontn 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-18-2009 11:55 AM
