Indexing Spark Plugs - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-23-2012, 02:01 AM Thread Starter
kilkm68's Avatar
I know there is a difference of opinion as to if there is any benefit to this or not, but I think I'll try it when I change the plugs in the spring. Different threads I've read on this give different directions. Some say to orient the gap toward the intake valve others the exhaust and one I just read said away from the combustion chamber and toward the cylinder? What's your opinions/experiences and what about the E3 spark plugs that don't need indexed?
kilkm68 is offline
post #2 of 3 (permalink) Old 12-23-2012, 11:14 AM
Quoted: 102 Post(s)
On a cutting edge, all-stops-pulled maximum build, perhaps a very minor gain in power. On a street driven engine, Zip. You won't feel a thing. Not worth the bother unless you "want" to. (I still mess around with points ignitions because I think it's fun). Go for it, just don't expect much.
post #3 of 3 (permalink) Old 12-23-2012, 11:14 AM
My opinion? I can't prove that it helps any, but it sure can't hurt. It's an easy thing to do, all it takes is a little time and patience. I indexed mine, and I pointed the "open" side of the plug towards the intake valve. It's something that race teams do, so they must think it matters.
I don't have an opinion on the E3's. I've seen side-by-side "tests" on TV where they supposedly make a difference but then those same shows usually also run ad spots for them, so I'm cautious about that.
Spark plugs albatross 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 09-13-2011 05:15 PM
Spark Plugs... Leahburk714 Engine Discussions 5 06-15-2011 11:58 AM
Spark Plugs trialsmm 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 03-02-2011 09:34 AM
Spark Plugs alsgto04 Service, Maintenance and Technical Discussion 7 11-04-2008 06:01 AM
What spark plugs for the ls2? Ozzhead Service, Maintenance and Technical Discussion 22 02-18-2008 12:23 PM
