Intake Manifold question - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-25-2010, 09:27 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
I found the intake manifold for my 67 Goat.
wha are those 'cuts' in the metal?
they look like they are supposed to be there,
thanks as always
ID:	9787   Click image for larger version
Topkat is offline
post #2 of 4 (permalink) Old 12-26-2010, 08:24 AM
Send a message via MSN to GonOvr Send a message via Yahoo to GonOvr
you are correct, might of had a problem with the manifolds cracking? Might have the slits in them to relieve stress when bolting the intake down? Im completely guessing but it sounds good to me.
GonOvr is offline
post #3 of 4 (permalink) Old 12-26-2010, 11:38 AM
I always thought it was for expansion and contraction. It gets real hot there where the exhaust cross over is. I may be wrong.
dimitri is offline
post #4 of 4 (permalink) Old 12-26-2010, 04:02 PM
Those cuts isolate the exhaust x-over from the rest of the intake, they mostly keep the manifold from cracking. FYI, on some manifolds the front part (WATER CROSSOVER) is completely seperate. If you want to switch intake manifolds, you need not open the cooling system!
Eric Animal is offline
Ls6 intake manifold question... stealth gray goat Intake and Exhaust Discussions 3 12-17-2009 02:12 PM
'66 Gto Intake Manifold Question take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-02-2009 08:55 PM
Intake Manifold Value rollieman 1964-1974 Tempest, Lemans & GTO General Discussion 2 02-19-2007 11:33 AM
