intake missing something - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-28-2011, 12:02 PM Thread Starter
68GTO4004Spd's Avatar
What is supposed to go here and what does it do? Anyone know what the thread size is so I can just plug it?
68GTO4004Spd is offline
post #2 of 5 (permalink) Old 06-28-2011, 12:12 PM
Thumpin455's Avatar
I run my mechanical temperature gauge sender there, or the other side. They usually had a thermal switch that opened vacuum to something once the engine warmed, or close it off after a certain temp was reached. On a 68/69 it might have been the heat riser door in the air filter housing, those flaps in the snorkel would open and close to allow heated air from the exhaust to warm the intake to help with cold weather drivability. Later engines used those for part of the EGR system. I have a couple of those plugs in the shop and a bare intake I just had cooked, if I remember I will measure the hole so you can plug it with a pipe plug if you want.
Thumpin455 is offline
post #3 of 5 (permalink) Old 06-28-2011, 12:45 PM
Remove the plug, take it to a local parts store and they will give you a plug the right size.
post #4 of 5 (permalink) Old 06-29-2011, 07:34 PM
pipe plug, but if yours is tight and not leaking, have seen the threads pull out when old fitting is removed. Based on the water neck corrosion, I would not mess with it or be prepared if necessary to pull intake off for it to be fixed properly.
pontiac is offline
post #5 of 5 (permalink) Old 06-30-2011, 08:45 AM Thread Starter
Too late, it's allready out, I just don't want to put that scraggley thing back on there. I just wanted to know what that thing used to do and what the size was.
Missing trim plate ? droptopgto 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 02-20-2011 07:59 AM
missing my car... xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 23 07-02-2010 04:47 PM
missing trim piece crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-28-2009 03:36 PM
0-60, What am I missing? noz34me 2004-2006 GTO General Discussion 9 02-16-2006 10:06 PM
cant break eights, what am i missing? DK2F Service, Maintenance and Technical Discussion 30 02-10-2006 12:25 PM
