intake O ring - Pontiac GTO Forum
post #1 of 8 (permalink) Old 02-09-2011, 07:26 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
intake O ring
Do I need to put sealand on the waterpump housing to intake manifold O ring?
thanks as always
Topkat is offline
post #2 of 8 (permalink) Old 02-09-2011, 07:48 AM
thanks as always
do you absolutely need to? no but i would. a tiny film of silicone.
freethinker is offline
post #3 of 8 (permalink) Old 02-09-2011, 08:05 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Silicone and rubber don't usually stick well. If you use the silicone, clean the matting surfaces to sterile with denatured alcohol or acetone. ANY oil film will prevent silicone from adhering.
I like to have the water pump installed first and leave the intake bolts slightly loose. Then use the water pump bolt to pull the intake forward a little to lightly compress the O-ring seal. Just a firm, snug, pressure on that bolt will be enough, or things will break or strip.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #4 of 8 (permalink) Old 02-09-2011, 08:19 AM
We use a "dab" of Permatex "Aviation" to hold the o-ring in place (in the intake) while droping it onto the engine.
Agreed with the process.
Jim
Mr. P-Body is offline
post #5 of 8 (permalink) Old 02-09-2011, 12:22 PM
Quoted: 117 Post(s)
Also, a little anti-sieze on that long thin bolt is always a great idea. Not too tight, and it's the first one you tighten.
post #6 of 8 (permalink) Old 02-09-2011, 02:45 PM Thread Starter
Topkat's Avatar
It occures to me that i painted both surfaces that the TC cover to intake manifold rubber grommet mates.
Hoping I dont have to scrape the dam paint off and contaminate the water pump and intake manif?
thanks all
Topkat is offline
post #7 of 8 (permalink) Old 02-09-2011, 03:19 PM
thanks all
Ifn' it was me, I would. Jam a piece of rag or somthing into both the holes to keep the paint chips from getting in, then use the rubber washer to mark the circles, then use some sandpaper or a gasket scraper to take the paint off just where the washer sits. It'll "probably" be ok with the paint, but as easy as it is to fix, why take the chance?
post #8 of 8 (permalink) Old 02-09-2011, 06:56 PM
Quoted: 117 Post(s)
I think it will be okay with the painted surfaces, too. As stated, pretty easy to remove, just don't gouge the aluminum....paint remover or carb cleaner maybe??
Ring Gap size liljohn442 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 01-24-2011 04:31 PM
Horn Ring Removal Al T 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-02-2010 06:55 PM
Trim Ring Sizing xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 4 08-11-2009 11:51 AM
Ring a bell housing VettenGoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-15-2008 05:40 PM
