intake vaccuum - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-10-2011, 05:15 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
intake vaccuum
why are there 2 seperate connections on my intake manif for pcv?
thanks as always
Topkat is offline
post #2 of 4 (permalink) Old 02-10-2011, 05:26 PM
The other one is for accesories, or not used and plugged. Did you look at that GM starter shim kit that inlinetube sells for $8.00? It's a great kit.
dimitri is offline
post #3 of 4 (permalink) Old 02-10-2011, 05:37 PM
thanks as always
there is a plastic fitting that looks like an f to connect them to the pvc hose. i think its designed to balance the vacuum between the intake runners.
http://www.pysales.com/IW_Products.m...;SEARCH_SUBMIT
RPE368 - PCV VENT HOSE CONNECTOR - 66-67 4-BBL
Price In Stock? Qty in Cart
16.00 Yes
freethinker is offline
post #4 of 4 (permalink) Old 02-10-2011, 05:53 PM
Quoted: 103 Post(s)
Freethinker is correct. Your PCV line goes to both fittings. There is a special nylon "Tee" that is unique to your car. The vendors have them ...it's not cheap for what it is. The '67 has a "dual plane" intake and you get PCV vacuum from both ports.
vaccuum Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 12 02-03-2011 09:13 AM
F.a.s.t Intake dizzy1 Intake and Exhaust Discussions 3 05-30-2007 03:25 PM
Which intake is this? Hheat Intake and Exhaust Discussions 6 02-16-2007 12:56 PM
SS Intake svede1212 Intake and Exhaust Discussions 2 05-19-2006 09:46 PM
One-off intake. ouijaguy Service, Maintenance and Technical Discussion 12 09-14-2005 05:34 PM
