Intermediate oil pump shaft? - Pontiac GTO Forum
 1Likes
  • 1 Post By bigD
post #1 of 5 (permalink) Old 02-12-2017, 09:10 PM Thread Starter
Ok, i had a major brain fart and left out my intermediate oil pump shaft, and already installed notor trans in car.with that said has anyone ever ground off the nubs on the shaft and installed it from the top.??
Id hate to have to pull the motor out again..
Any ideas? Thanks
SKIDLOADER10 is offline
post #2 of 5 (permalink) Old 02-13-2017, 09:32 AM
shader's Avatar
Quoted: 9 Post(s)
Do a search on this forum for something like oil pump shaft. There is a fairly recent comprehensive post about a similar problem.
The same thing happened to me when I built my first Pontiac engine. I ground off the nubs and inserted the shaft from the top. Do it slowly and make sure the intermediate shaft is seated on the oil pump driven gear shaft. However problems may arise if you have to remove the distributor. The intermediate shaft may stick to the distributor then fall off into the engine.
On my 64 I was able jack up the engine and loosen the oil pan. This gave me enough clearance to unbolt the oil pump and install the new shaft.
shader is offline
post #3 of 5 (permalink) Old 02-13-2017, 10:15 AM
1968gto421's Avatar
Quoted: 72 Post(s)
Pete McCarthy a well known Pontiac racer (now retired) has written several books on building Pontiacs--he says its perfectly fine to do as Shader says to grind off the nubs and insert from the the top.
Best of luck.
Name:	Pete's Pontiac.jpg
1968gto421 is online now
post #4 of 5 (permalink) Old 02-13-2017, 03:48 PM
Quoted: 69 Post(s)
I've done it, too.
I used long needle nose pliers. There may be a better tool. ??
And, as said, be careful to get it properly seated on the pump.
Name:	Long Needle Nose .jpg
1968gto421 likes this.
bigD is online now
post #5 of 5 (permalink) Old 02-13-2017, 05:48 PM Thread Starter
Perfect thank you!!
Low Oil Pressure-Bad Oil Pump PontiacJim 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 09-23-2014 03:03 PM
'69 GTO-Intermediate Steering Shaft Boot Clamp rvp986 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-09-2013 08:01 AM
oil pump Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 5 03-06-2011 12:42 AM
Oil Pump Richtenb Service, Maintenance and Technical Discussion 5 02-15-2010 01:04 AM
05 Oil Pump GTOGuy Service, Maintenance and Technical Discussion 1 09-22-2005 09:02 AM
