Its still on Overheating Problem - Pontiac GTO Forum
post #1 of 16 (permalink) Old 07-13-2009, 04:49 PM Thread Starter
Im not Sure were to go, with this. Car seems to still get Hot. Must tell you guys that a have a new shrould and radiator now thermo is 180, but I'm putting an 160 in. Is it just because on this heat that its running 225- 235? I have an flex fan. I have checked my timing, its set at 6 deg. So I pretty much don't know where to go from here. If you can help that would be great. Im also using Waterwetter. Thanks Herb. P.s. sorry for any miss spelled words.
POOF is offline
post #2 of 16 (permalink) Old 07-13-2009, 05:39 PM
jetstang's Avatar
If it's hot at idle, but goes down when you are at speed, then your fan is inefective. If it's hot idle and moving, then it may be a clogged radiator, non-flowing water pump or other internal problems. 220 -230 isn't overheating, just hot, and already addressed in other threads.
jetstang is offline
post #3 of 16 (permalink) Old 07-13-2009, 08:14 PM
Quoted: 103 Post(s)
post #4 of 16 (permalink) Old 07-14-2009, 03:26 AM
Koppster's Avatar
You can do a flow check by disconnecting the upper radiator hose while cold, starting the motor and watching to see when water begins to flow. Thermostat should open at 180 and flow should be good. The results might tell you something about your water pump and the flow within the motor channels. If you have a new radiator, that's the next place I would look (motor/pump).
Most of the posts I have read, criticize the flex fans, you might want to consider a solid or the electric fans.
Koppster is offline
post #5 of 16 (permalink) Old 07-14-2009, 08:17 AM
try advancing the timing....6 degrees sounds low.....
judgeman6970 is offline
post #6 of 16 (permalink) Old 07-19-2009, 04:50 PM
yes a 160 thermostat will make a big difference. also put water wetter in at the same time. these changes may lower temp 20-30 degrees.
auburnconsulting is offline
post #7 of 16 (permalink) Old 07-21-2009, 07:32 PM
loose the flex fan, check the fan blade to radiator clearance,make sure your water pump plates are in good shape, buy a GOOD radiator. Eric
Eric Animal is offline
post #8 of 16 (permalink) Old 07-26-2009, 09:56 PM
jetstang's Avatar
I agree with Eric, make sure the diverter plate is installed. Also, make sure you have a good quality water pump, it may be bad flow. Also, you can install an electric fan with a thermostat switch to turn on at a certain temp, 190-above the stat temp to keep amp draw low. Radiator may be clogged and need replacing.
Just keep at it and I'm sure you will find your demon.
jetstang is offline
post #9 of 16 (permalink) Old 07-27-2009, 08:13 PM
what is the best fan setup for the 1967 400? chronic hot runner
goat670 is offline
post #10 of 16 (permalink) Old 07-30-2009, 10:07 PM
johnnylightning03's Avatar
are the belt(s) tight enough or glazed? flex fan may be causing water pump pulley to slip while at speed. i know its basic, just a thought though. good luck.
johnnylightning03 is offline
Weird problem with LCD after car didn't start CrazyGerman Service, Maintenance and Technical Discussion 1 03-29-2009 08:38 AM
Electronic throttle control problem Ole school muscle Service, Maintenance and Technical Discussion 3 01-18-2008 10:25 AM
Potentially serious GTO problem - everyone inside! Yankee Drive train, suspension, alignment and brakes. 67 04-22-2007 07:10 PM
one problem down one to go my1971gto4spd 1964-1974 Tempest, Lemans & GTO General Discussion 14 04-19-2006 10:25 AM
GTO Automatic Shift Problem smckullie Service, Maintenance and Technical Discussion 5 02-23-2005 06:02 AM
