Key doesn't turn 72 off.. What's the likely cause? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-20-2014, 12:25 PM Thread Starter
Smalldog's Avatar
My 72 won't turn off with the key, and I have to pull the alternator wiring plug to turn it off.
From my research it seems it would be the ignition switch.. But to add a wrinkle, I have a kill switch that is working properly but I suspect that could be the culprit as well.
Any tips on installing a new ignition switch if that's what I need to inspect or replace? Thanks!
Sent from AutoGuide.com App
Smalldog is offline
post #2 of 4 (permalink) Old 04-20-2014, 01:43 PM
Hmmmm...that kill switch could be suspect depending on how it is wired in.
Is it some sort of theft deterrent system?
Ignition switch is relatively easy to replace.
post #3 of 4 (permalink) Old 04-20-2014, 07:09 PM Thread Starter
Smalldog's Avatar
Thanks Alky. It's a deterrent to power the ignition to start it up. It might slow a dumb criminal down a bit
Since the kill switch works as always I'll probably get a new ignition switch and take a stab :
Smalldog is offline
post #4 of 4 (permalink) Old 04-21-2014, 11:09 PM
The ign. switch should take about 10 min's. to replace & adjust will take a little longer, but you should have it done in about 1/2 hour. The kill switch depending on how you have it wired in may be the cause of the switch going out to. I'd disconnect it before you replace the switch so you don't burn another one up.
rexs73gto is offline
key won't turn! banshee Service, Maintenance and Technical Discussion 21 07-19-2010 09:02 AM
key wont turn...plz help. =[ GTO19020 Service, Maintenance and Technical Discussion 4 10-19-2009 03:10 PM
Help!! Cant Turn Key gto4H0P0 2004-2006 GTO General Discussion 12 03-15-2009 09:08 PM
Key Won't Turn GM Kid 2004-2006 GTO General Discussion 31 10-01-2008 09:59 AM
Ignition key fail to turn over! Black_Goat Service, Maintenance and Technical Discussion 2 10-18-2005 09:30 PM
