leaky carb - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-11-2011, 09:24 AM Thread Starter
leaky carb
hi, I have a '66 GTO with tri-power. When I started it last week, after sitting for a month, it was running rough. I then noticed gas pouring out of the front carb from around the pump shaft, and raw gas was also filling up the barrels. I've replaced the needle & seat, the gasket between the air horn and throttle body, and adjusted the float. The brass float is intact, no leaks. Now the problem is, if anything, getting worse. Could this actually be a fuel pump issue? Any ideas would be much appreciated.
Red Doggy is offline
post #2 of 2 (permalink) Old 04-11-2011, 02:38 PM
Not a pump problem but a carb problem. Recheck the float, it may be bad. Be sure the needle and seat are installed proper and that it has the little gasket under it.
Leaky Window Nomad 2004-2006 GTO General Discussion 0 01-23-2010 12:12 PM
Leaky steering box 66 LeMans 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 07-27-2009 07:26 AM
Leaky seals purplehaze Service, Maintenance and Technical Discussion 2 01-01-2007 02:48 PM
Leaky Goat marathonman Service, Maintenance and Technical Discussion 11 06-26-2005 08:47 PM
Help with leaky Trunk Judge 2004-2006 GTO General Discussion 3 06-11-2005 07:55 AM
