leaky turbo 350 question - Pontiac GTO Forum
post #1 of 7 (permalink) Old 11-21-2009, 06:49 PM Thread Starter
Just put a turbo 350 into my lemans. It has a 1970 pontiac 350 motor. The leak is after I drive it and turn it off, it drips a fairly significant amount from around the torque converter, maybe a teaspoon each side (no dust plate installed yet). The kick down, lines, modulator, shifter, rear seal, all seem to be holding good but it's leaking from around the converter. And it doesn't seem to leak while running. When I bolted the TC to the flywheel, it did pull forward to the wheel about 3/8 inch. I'm wondering if it is not seated back far enough? I could definately fit some washers between the TC and the flywheel if this would help? Thoughts? Appreciated it.
67lemans is offline
post #2 of 7 (permalink) Old 11-23-2009, 05:37 PM
It could be a bad seal or oil pump drive bushing. I wouldn't shim it out with washers cause the center if it is supposed to insert into the end of the crank for stability. Shim it out and only the flex plate will be supporting the converter. Try this, loosen the torque converter, rotate the motor a few times, re-tighten the torque converter.
post #3 of 7 (permalink) Old 11-23-2009, 08:48 PM Thread Starter
Thanks, won't hurt anything to try.
BTW, just as a fyi, I had heard the turbo 350 was basically a plug and play for the power glide, but in my case I found the dip stick needed to be, lets say, "modified" to fit properly. This was not a big deal but probably took longer than the rest of the destall install. Thanks for all the tips!!
67lemans is offline
post #4 of 7 (permalink) Old 11-23-2009, 09:21 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Did you try the tube from the P/G to see if it worked in the 350 case. I don't remember if they were located in the same place, but the curve would fit the firewall.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #5 of 7 (permalink) Old 11-23-2009, 09:23 PM
646904GTO's Avatar
In hindsight I always replace the front seal of an auto if I install one. The price/headache ratio supports this path.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #6 of 7 (permalink) Old 11-23-2009, 09:50 PM Thread Starter
Mine was actually a super turbine 300 instead of a power glide. I did try that but the the angle and length in which they enter the body of the transmission are completely differen.
67lemans is offline
post #7 of 7 (permalink) Old 11-23-2009, 09:54 PM Thread Starter
I think you are dead on. I did give the front seal bolts a mild tighten prior to the install. Probably a rebuild to some degree would have saved some headache. Live and learn.
67lemans is offline
Identifying this engine? rnldmdmb 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 16 08-28-2009 08:43 AM
Valve Cover Opinions Please Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 42 02-19-2009 09:13 PM
Engine code and date discrepancy - HELP!! Mcantw 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 16 02-13-2009 09:04 PM
Question about the 350 H.O. Darren Service, Maintenance and Technical Discussion 3 12-19-2004 07:34 PM
