LED's - Pontiac GTO Forum
 1Likes
  • 1 Post By CBarrett
post #1 of 9 (permalink) Old 09-20-2015, 07:31 PM Thread Starter
Guy B's Avatar
LED's
I'm toying with the idea of changing out all of the bulb lights in my 68 GTO convertible with LED's.......except headlights.
Although it's basically a numbers matching original.....I think not taking advantage of new technology for better lighting (safety) could be a mistake.
Is there anyone utilizing LED's on their car(s)....Pros-Cons? Advice? Feedback?
As Always...Thanks!
Guy B is offline
post #2 of 9 (permalink) Old 09-20-2015, 07:47 PM
pjw1967's Avatar
Great question! I too am interested. In my investigations I saw that the flashers need to be changed as the LED bulbs don't offer enough resistance. Also, someplace I saw that you should use red LED's in the taillights instead of white. Hope there is someone out there whose done this.
pjw1967 is offline
post #3 of 9 (permalink) Old 09-20-2015, 09:08 PM
Quoted: 106 Post(s)
The only ones I would do are the GI lights in the dash, get the 12V super bright cool whites, they have a slight blue hue and you can actually see the heater controls as well as the other instruments at night and they work with the dimmer.
The '67 takes 7, 8 if you want to change out the glove box light.
I tried a few in other locations, don't waste your money.
Goat Roper is offline
post #4 of 9 (permalink) Old 09-22-2015, 03:42 PM
crustysack's Avatar
I put a LED dome light in, much cooler and you can leave the door open for hours
crustysack is offline
post #5 of 9 (permalink) Old 09-22-2015, 09:57 PM Thread Starter
Guy B's Avatar
Anyone using LED brake-light kits?
Guy B is offline
post #6 of 9 (permalink) Old 11-19-2015, 11:59 PM
I put Dakota Digital LED tail lights in my 65 goat. They are a board of LED's that stretch across the entire tail light. They are only offered for 65 - 68 though, and are not cheap. Daytime visibility of the brake lights are great, didn't have to change the flashers, not to hard to install. I put a Dakota Digital instrument cluster in also, as the original cluster just didn't light up very well. Extremely nice package, also, not cheap! Has many features, check out their site, <dakotadigital.com>. I also change my headlights over to HID. I found AUTOPAL 146 mm halogen head lamp units that except H4 bulbs, got those off E bay, and HIDeXtra bulbs that have an H4 mount. They are super bright, I went with the 55 watt power series. Still has the sealed beam look, you would never know they are HID's until you turn them on. Will post some pictures when I can, she's up on jack stands now changing axle seals and bearing, and rebuilding center carb. Hope this helps anyone, have not had any issues with any of this equipment and I have had them in for almost two years now.
deanhickey likes this.
CBarrett is offline
post #7 of 9 (permalink) Old 11-20-2015, 12:02 AM
Also, hold on to any OEM parts you upgrade. If you still have the originals, you haven't lost any value.
CBarrett is offline
post #8 of 9 (permalink) Old 03-05-2018, 10:11 AM
Quoted: 155 Post(s)
Bump for an update....Who has installed LED interior lights and what do you think ? The standard bulbs get so crazy hot!!!
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #9 of 9 (permalink) Old 03-05-2018, 10:59 AM
1968gto421's Avatar
Quoted: 72 Post(s)
I would be interested in this for safety's sake.
1968gto421 is online now
LED Bulbs Miami Ragtop 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 12-26-2014 08:18 PM
led pigtails The Black Mongoose Exterior Discussions 0 08-18-2014 05:08 PM
LED lights going out motoristx Interior Discussions 0 02-20-2011 12:09 AM
Installed LED's this weekend efitzgerald1231 Interior Discussions 4 11-30-2007 08:15 AM
New LED's thanks to GTPprix! marathonman Interior Discussions 13 03-24-2006 11:28 AM
