lifters - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-06-2011, 04:15 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
lifters
tomorrow I want to put the lifters in,the service manual says to put heavy oil on the bottoms of them.
they are soaking, and since it's going to be months yet before im ready to start it, is it okay to put greese on the bottoms of the lifters?
thanks as always
Topkat is offline
post #2 of 5 (permalink) Old 02-06-2011, 08:43 PM
thanks as always
yes. i do and i have never had a cam problem.
freethinker is offline
post #3 of 5 (permalink) Old 02-07-2011, 08:19 AM
Rather than some "generic" grease, use a moly-graphite assembly lube. It's a dark gray "paste" and stays on the lifters for a LONG time (years).
Jim
Mr. P-Body is offline
post #4 of 5 (permalink) Old 02-07-2011, 09:11 AM
Quoted: 117 Post(s)
Yes. Do NOT use "white lithium" grease. Over time, It turns into cement. I've seen one ongine that was overhauled and "put up" (for years, though), and it siezed up during it's storage. The differential thrust washers in my '15 Ford were "prepped" with white lithium grease and the car was stored for years. I bought it, and when I got it on the road, promptly had a rear thrust bearing failure. I still have the bearing...it's like it's caked in concrete. Cam lube is your friend!
post #5 of 5 (permalink) Old 02-07-2011, 02:14 PM
chuckha62's Avatar
Quoted: 18 Post(s)
As an aside... When you're ready to fire her up, make sure to use an oil high in ZDDP (a zinc additive) to do your cam break-in. I used Rotela on my last one. ZDDP and a proper break-in on your cam and you should be worry free!
chuckha62 is offline
Cam / Lifters Problem on Restart peahrens 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 15 01-31-2011 11:21 AM
new lifters installed. Easiest way to adjust ??? wlbuckles 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-26-2010 10:59 AM
5 lifters not pumping up? zzomby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 09-10-2009 11:53 AM
Feedback on a Cam Swap and Rhoads Lifters 1AMike 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 7 07-26-2009 09:35 PM
lifters NEXSTAR7 Engine Discussions 15 07-24-2009 06:55 PM
