A little heart broken... - Pontiac GTO Forum
post #1 of 25 (permalink) Old 01-31-2013, 04:21 PM Thread Starter
OrbitOrange's Avatar
I restored my 70 GTO, and pulled the matching numbers engine during the process. I didnt have money to have it built so I through a fresh poncho 350 in and been using it ever since. ( little over 2 years now.) Well Monday I finally broke down and took the 400 to the machine shop. I hadnt taken it in 2 years because I had to beat the pistons out of the block so I didn't have high hopes for it. Got the call this morning on my drive to work that it is going to need to be bored out to .060 and needs 3 sleeves because the rust in the cylinder pitted it that bad. $450 for the sleeves and then $80 to bore all 8 cylinders.
Well I thought on it some this afternoon and after calling Butler Performance for some opinon and advice. They advice against more than 1 sleeve per bank. And also .060 max bore. And I gotta say I agree. Who wants to put in 3 sleeves and then have to turn around and bore them to max bore?
Looks like I am in the market to find another block, or do some work on the 350 I have now.. I would like to fit my #13 heads to the 350, but I gotta have the heads checked out also and see howbad the rust is in the valve seats on them now.
Your thoughts guys?
OrbitOrange is offline
post #2 of 25 (permalink) Old 01-31-2013, 04:59 PM
Quoted: 98 Post(s)
Butler has a great reputation, and are highly thought of. That said, how about getting a second opinion, just to be sure? Jim at Central Virginia Machine would be my next call. I have heard of many sleeves going into an engine, but I am no machinist. Multiple sleeves might be a no-go on a race engine, but could possibly be do-able on a street build. If it were me, I would source another 400 block, age approximate, and build that. I would then oil, bag, and store the original #'s block and hold on to it. You never know. I would not spend the $$$ on the 350 engine. I would either run it as is, like you have been doing, or yank it for a replacement with a 400.
post #3 of 25 (permalink) Old 01-31-2013, 05:43 PM
And keep in mind that Butler's recommendation probably didn't take into account the fact that it's the numbers-matching engine. "Normally" they'd be right - it's probably not worth the expense - but this isn't a "normal" case. Keeping that block just might be worth it.
post #4 of 25 (permalink) Old 01-31-2013, 10:34 PM
Quoted: 23 Post(s)
have a 70'400 virgin block at the machine shop cleaned checked and ready to bore. I may be selling, have to get up and grab it as i lost the block codes and need to get it back to the shop.
Instg8ter is offline
post #5 of 25 (permalink) Old 01-31-2013, 10:34 PM Thread Starter
I plan on keeping the block. Just think I might need to find another one to put into service now. I figured if the heads are shot also. Just for nostalgia, conversation piece in the garage. I Might bolt the heads on the block with the factory intake and paint it up like new and let her set in an engine stand in the garage.
Hard to believe someone let it end up like this. It has never been bored, and even had an erson cam in it when I pulled it apart. Sad, really. It was like someone robbed it for parts for some reason because it was missing lifters and pushrods. Or either someone started building it and never finished it. Probably sat in a field and got rained on for years and seized up.
post #6 of 25 (permalink) Old 01-31-2013, 10:37 PM Thread Starter
That would be nice but probably out of my budget. A friend called today said he was working at a guys house, and this guy said he used to race pontiacs back in the day and that he had a complete 400 with heads on it but it was wore out and would need a bore. Said he would take $100 for it. I think I need to go take a look at this asap.
post #7 of 25 (permalink) Old 02-01-2013, 07:24 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Re: A little heart broken...
Agreed, sounds like it may be a bargain
FlambeauHO is offline
post #8 of 25 (permalink) Old 02-01-2013, 08:35 AM
FNG69's Avatar
Know of a engine that had all 8 cylinders sleeved!! And then build to stock. Jumped in the GTO after couple years and drove all across the USA. Just saying its been done!!
FNG69 is offline
post #9 of 25 (permalink) Old 02-01-2013, 12:06 PM Thread Starter
Thought about that also. But at $100 per hole labor and $30 per sleeve. $1040 just to get the block usable I can't justify. Gonna get over and look at this $100 engine and see whats going on there.
I just hate that now I gotta go pay $100 to the machine shop for magnaflux and vatting the original block thats going to be a paper weight.
post #10 of 25 (permalink) Old 02-01-2013, 12:22 PM
Quoted: 98 Post(s)
It depends on what the car is, how rare, etc. I was speaking with Jim Wangers two years ago, and He informed me that an original (born with) engine adds about 10,000 dollars to the value of the car. In checking prices on restored and survivor cars, I have found that this is pretty accurate. $1040 is peanuts when you consider the whole equation, value wise.
Heart Attack Grill serves bypass burgers, flatliner fries batmans The Lounge 8 02-24-2011 09:26 PM
64 Roadracer's gets a new heart 646904GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 12-06-2009 03:08 AM
broken key koman 2004-2006 GTO General Discussion 15 06-26-2008 12:14 PM
Car Broken Into! GTOJon 2004-2006 GTO General Discussion 11 05-02-2005 11:33 PM
My GTO got broken it! qonoximiento 2004-2006 GTO General Discussion 10 01-10-2005 09:58 AM
