Location of Ignition Coil for 65 GTO Tripower - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-01-2012, 02:42 PM Thread Starter
Could someone tell me where the ignition coil would be mounted on a 65 GTO with a Tripower intake? What type of holder would be used and where could I purchase the holder . When I bought the car it had a large aftermarket coil mounted on the Firewall which I have removed as I want to install a stock coil in the correct location. Thanks
timmyg is offline
post #2 of 5 (permalink) Old 05-01-2012, 03:46 PM
Here is an aftermarket bracket from OPGI. Below are pictures of the bracket on my 66 with a Carter 4bbl. The bracket was located in the same place for both years.
ID:	14637   Click image for larger version
ID:	14638   Click image for larger version
05GTO is offline
post #3 of 5 (permalink) Old 05-01-2012, 06:02 PM
Quoted: 100 Post(s)
Yes, '65 is the same. Mounted on the back side of the passenger side cylinder head.
post #4 of 5 (permalink) Old 05-01-2012, 06:43 PM
rickm's Avatar
Quoted: 5 Post(s)
you should buy a '65 shop manual from ames performance. its well worth it.
rickm is offline
post #5 of 5 (permalink) Old 05-02-2012, 11:19 AM Thread Starter
Thanks for the help and the pictures. I didnt know if the shop manual would go to that detail, but if it will, I will definately get one from Ames. I already got the wiring booklet from them.Thanks a lot
timmyg is offline
tripower 455(71)HO vs my 69 400 EP Goat 2004-2006 GTO General Discussion 1 05-18-2011 04:21 PM
ignition coil replacement BLUE04 Service, Maintenance and Technical Discussion 4 12-15-2010 03:37 AM
Coil location on '70 RAIV? Doug D 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 05-25-2010 12:50 PM
67 Ignition Coil Location rollyman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 05-15-2007 02:54 PM
