Look at what I did today - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-06-2014, 10:56 PM Thread Starter
69Goatee's Avatar
I haven't posted here in a long time, but I have been hard at work on the GOAT. Finally, I got to drive her today around the block! I pulled it into the garage eight years ago and it sat for two years or so collecting junk and leaking everything. The original plan was to get the transmission rebuilt, fix the leaks, redo the wiring, replace the body mounts, do the bodywork and get it ready for paint. Well, the more I dug into it, the more problems I found. I ended up taking everything off that was bolted on, leaving just the body shell and bare frame. I took the body off the frame to repair where the mounts had rusted through. I then POR-15'd the entire frame, rearend and the front a-arms, under coated the body.
I smoothed the firewall and POR'd it also, replaced the drivers side quarter panel and drivers floorboard. Both fenders got patch panels. I had hardened exhaust seats put in the heads, and I put a BOP rear main seal in. I put a Lunati bracket master 2 cam in it with roller rockers. The transmission was rebuilt and I put a "Switch Pitch" kit in it with a 1800-3000 stall. I built the alternator and power steering brackets and put a Hydroboost on it with a modern power steering pump.
I could go on for pages and pages on what was done to it, but I will let pictures do the talking. The last picture is where the Goat has spent the last eight years.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #2 of 6 (permalink) Old 04-06-2014, 11:01 PM Thread Starter
69Goatee's Avatar
Can't seen to get all pictures to load on original thread.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
post #3 of 6 (permalink) Old 04-06-2014, 11:03 PM Thread Starter
69Goatee's Avatar
Another
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
post #4 of 6 (permalink) Old 04-06-2014, 11:04 PM Thread Starter
69Goatee's Avatar
Last one.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
post #5 of 6 (permalink) Old 04-07-2014, 07:48 AM
Congratulations!
post #6 of 6 (permalink) Old 04-07-2014, 01:56 PM
jmt455's Avatar
Congrats on a major milestone!
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
Getting My '66 Today Baltimoron 1964-1974 Tempest, Lemans & GTO General Discussion 6 02-26-2012 11:36 PM
New Today shifter25j Member Introductions 2 06-11-2010 04:09 AM
What I did today geeteeohguy 1964-1974 Tempest, Lemans & GTO General Discussion 9 02-23-2009 02:43 PM
Saw one today deftec The Lounge 8 03-05-2005 02:48 PM
I got one today Phoenix 2004-2006 GTO General Discussion 12 12-29-2004 12:06 PM
