Looking at a 67 GTO to buy what should I look for - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-01-2006, 11:49 AM Thread Starter
Hi, I going to look at a 67 GTO rag top w/a 4spd. Car hasn't been driven in two years and will not start. What are some of the things I should look at before I buy.
Jim
jim's68 is offline
post #2 of 7 (permalink) Old 05-01-2006, 01:06 PM
If your looking for the car to be a numbers correct GTO look at the block casting number, engine letter code, production date code, vin and data plate. Also, check the transmission codes.
Good luck,
05GTO is offline
post #3 of 7 (permalink) Old 05-01-2006, 05:58 PM Thread Starter
Randy, any idea what a good price would be for a 67 in pretty good shape. It does need some work has some rust & wear, it is a driver not a show car. And not going to be a show car but I intend to make it a cool hot rod. No plans on selling it.
Jim
jim's68 is offline
post #4 of 7 (permalink) Old 05-01-2006, 09:51 PM
Jim,
Around 50 are listed on http://www.collectorcartraderonline.com, starting at around 5 K (without motor and tranny) and going up to 100 k.
Lars may be able to give you a better idea of the value,
Good luck,
05GTO is offline
post #5 of 7 (permalink) Old 05-17-2006, 03:12 PM
1969+37=2006's Avatar
Get one with three 2 s, I think they still had that option in 67
1969+37=2006 is offline
post #6 of 7 (permalink) Old 05-17-2006, 04:14 PM
no tri power option in 67(1 good 4 bbl is better anyway)
check the frame where it goes over the rear end,they tend to rust out there
Jeffs386 is offline
post #7 of 7 (permalink) Old 05-18-2006, 10:49 AM
lars's Avatar
Last year for the Tripower ("Triple Power Pack") was 1966. No 400s built with the Tripower - they were all Q-Jet cars, which is a better setup anyway...
Lars
lars is offline
