losing voltage - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-26-2013, 08:22 PM Thread Starter
losing voltage
My 68 is losing voltage as I drive. I charged my battery and hooked it back up. It began around 12 on the volt gauge then as I drove it it went down to 10. My alt and voltage regulator r new. Would it be a short somewhere?
simmons68 is offline
post #2 of 5 (permalink) Old 05-26-2013, 09:18 PM
Just because the ALT and Voltage regulator are new, doesn't mean they are working correctly...there are a lot of defective parts around these days. I would check the alternator and BELT and connections first, then the regulator.....JUST SAYIN...Eric
Eric Animal is offline
post #3 of 5 (permalink) Old 05-27-2013, 08:47 AM
jmt455's Avatar
^X2 AND
Check all the ground connections, especially regulator to firewall and block to firewall.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 5 (permalink) Old 05-27-2013, 09:05 AM
...and, have you added any additional electrical load to the car? Big kicker stereo? Electric cooling fans? If so, the problem could be that the stock alternator just can't keep up.
post #5 of 5 (permalink) Old 05-27-2013, 11:07 AM
slapdash, stick it together, have a brew...
Ha! Just installed new alternator last weekish, and had to clock it- was just way off... Looked inside and saw the main wire from the windings that go to the inside of the threaded terminal lug, was on the lug, but MINUS the attaching nut, and the ground was just hanging on by a thread. Took it back & had them test it- of course it tested bad... I pulled the wire off it just to make sure it didn't work. Got a different style, different manufacturer. It said: hencho en Mexico- I told them the workers had too much cervesas -didn't tell them anything else. I wasn't too happy though! If I didn't look at the insides, I would have never known, and it may have charged initially, but would surely have gone out at any time! That's new crap part #1 this past week. I will be posting on crap part #2 here, presently... Stay tuned. It's a real good one...
gjones is offline
Still losing power xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 03-13-2012 07:34 PM
Losing power TxSoldier6.0 2004-2006 GTO General Discussion 3 02-15-2012 02:38 PM
Well...looks like we're losing another dragstrip. ALKYGTO The Lounge 2 10-28-2010 05:02 PM
Losing weight lnirenberg 2004-2006 GTO General Discussion 4 10-24-2009 03:03 PM
Losing your tune?? WanaGTO Service, Maintenance and Technical Discussion 9 05-13-2009 09:51 PM
