ls swap mounts - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-01-2014, 07:44 PM Thread Starter
ls swap mounts
hi guys dropping a ls3 into a 69 gto, i swapped oil pans to the gm muscle car pan and have ls swap mounts and chevelle mounts bolted to the frame, problem is that my oil pan rests on the crossmember and cant connect the mounts, super frustrated as every search iv done i see swaps done with the same mounts im using any useful knowledge would be super great
darrenh2 is offline
post #2 of 2 (permalink) Old 05-01-2014, 11:40 PM
Indecision's Avatar
I don't have any first hand knowledge, but the pan(s) on this page supposedly work. I plan to use their kit/pan when/if I do an LS swap on my 66. Hope this helps at least somewhat.
MuscleRods 68-72 Chevelle LS Conversion Kit
1966 GTO 428ci/4spd - spun bearing
Indecision is offline
Carrier Swap or Rear assembly swap AMT1379 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 07-21-2013 02:55 PM
front bumper swap back to stock, mounts? toegto Exterior Discussions 0 06-11-2012 07:23 PM
SCSS Mounts SWGOAT 2004-2006 GTO General Discussion 3 02-13-2012 10:58 PM
Hi....motor Mounts/tx Mounts 67conv? 67conv400 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 12-23-2005 07:53 AM
