m21 4 Spd muncie in a 64 lemans with a 400? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 03-14-2011, 10:53 PM Thread Starter
Seol21's Avatar
I have a 64 lemans i just picked up with a 400 auto tranny. I want to replace it with a manual tranny. Would a Muncie M21 work and how difficult would it be to install? Help pls!
Seol21 is offline
post #2 of 9 (permalink) Old 03-15-2011, 06:12 AM
Not difficult to install, just lots of parts to install. You will need pedals, the frame bracket that the z bar actuates on, it will need to be welded to frame. Then the following:
Clutch rod
Return springs
Shifter porch
Your engine needs to accept a pivot ball for the z bar
various clips
Ames is a good source, the best is find a donor car, or look on ebay.
All the above is given you want to make it look original. Hope it helps.
Sloan66 is offline
post #3 of 9 (permalink) Old 03-15-2011, 09:23 AM Thread Starter
Seol21's Avatar
Cool thank you. How about the actual mounting of the transmission. Will I need to modify anything on the frame?
Seol21 is offline
post #4 of 9 (permalink) Old 03-15-2011, 10:05 AM
FNG69's Avatar
When they put in the 400 they moved the cross member back around 6 inch's for the longer length of it which means they used a 400 drive shaft or shorted the original. Maybe it's a 350 and not a 400 cause that would be the correct length. Good Luck, Les
FNG69 is offline
post #5 of 9 (permalink) Old 03-15-2011, 10:07 AM
FNG69's Avatar
Have you posted any pictures yet. We Love Pics!!!!!!!
FNG69 is offline
post #6 of 9 (permalink) Old 03-17-2011, 01:17 AM Thread Starter
Seol21's Avatar
How about bellhousing and flywheel?
Seol21 is offline
post #7 of 9 (permalink) Old 03-17-2011, 06:37 AM
You can find them pretty easy on the internet or ebay. I have a pedal assenmbly and some misc. parts if your interested.
Sloan66 is offline
post #8 of 9 (permalink) Old 03-18-2011, 12:29 AM Thread Starter
Seol21's Avatar
yea im definitely interested. How much you willing to get rid of the pedal assembly for?
Seol21 is offline
post #9 of 9 (permalink) Old 03-18-2011, 10:13 AM
likethat's Avatar
PONTIAC GTO BELLHOUSING,FLYWHEEL,ETC
67 GTO H.O. Convert 4spd
likethat is offline
64 Lemans with a 400 auto tranny to manual Seol21 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-16-2011 08:31 AM
m21 wont go back in :/ tyler t 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 01-27-2011 05:41 PM
400 or 455 swap into '66 Lemans JB_Finesse 1964-1974 Tempest, Lemans & GTO General Discussion 4 07-15-2009 08:41 AM
