Main cap Question. - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-06-2012, 07:44 PM Thread Starter
Main cap Question.
So I picked up a 455 block to replace the 350 that came out of my 1972 Lemans sport. I took the block to a machine shop to have it checked out. I went back a month later (today)to drop off some other parts and he asked where the main caps were. When I told him it didn't come with any he told me it was a major problem and that the block would cost more than it was worth to find new caps and machine because the caps were made specifically for that block. He recomended I find a new block. He said i had payed way too much and i should be able to find a good 455 block for $350-$400.00 he also new a guy who might be able to help me find one. Other than the caps he said the block was in great shape. So my question is do you guys think he's telling me straight? Should I scrap the block and look for a new one with caps or try and find a set of caps that are close and machine them? Thomas.
BUSHMASTERW30 is offline
post #2 of 5 (permalink) Old 07-06-2012, 07:57 PM
Quoted: 105 Post(s)
You can buy brand new caps and have the machine wok done. Not even an issue, just more money. The block is NOT scrap. I would be inclined to check out other machine shops....
post #3 of 5 (permalink) Old 07-06-2012, 10:24 PM
Josh.AZ.GTO's Avatar
I agree ^ . I would just buy new main caps and use the block you have, if not then you just have a block that can't be used, the machinist said the block was good, why spend more money on another block. However, I'd get quotes from other places and possibly switch to a different machine shop if available.
JOSHUA
1970 GTO 455HO Cardinal Red
Josh.AZ.GTO is offline
post #4 of 5 (permalink) Old 07-07-2012, 08:39 AM
Time to find another machinist. Working on all those chevys has probably damaged his mental faculties
You could either find a set of main caps from any large journal Pontiac (421, 428, 455) as long as the rear seal and oil slinger matches what's in your block - then have them fit to your block via the align hone/align bore process, or you could get a complete set from places like Butler Performance (which would also need align bore/hone). The latter is pretty pricey for all 5 caps (it would be $630 for a complete set from Butler, but those would be 4-bolt center caps).
You have options - it's not as bad as you've been led to believe.
post #5 of 5 (permalink) Old 07-07-2012, 04:51 PM Thread Starter
Thanks for the info guys. I don't really know alot about engines but I'm not a complete [email protected]$4 either. I knew it couldn't have been as bad as I had been led to believe. Thanks again guys. Thomas
1966 GTO Rear Main Seal question Huckleberry66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-12-2012 05:34 AM
1966 GTO Main Bearing Seal Leak Question take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 01-31-2010 04:06 PM
Main Bearings MaL 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-30-2010 02:57 PM
"bolt main" question dustyminpin 2004-2006 GTO General Discussion 2 05-19-2009 01:34 PM
Main Seal stude368 Engine Discussions 4 11-03-2008 01:58 PM
