might be buying a 66 conv!!!!! - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-03-2009, 07:02 PM Thread Starter
what would i be getting into if i was to buy it??? the car has not been run in 5-10 years....what would some ideas be of necessary items needed to be fixed in order to get the car running and in drivign order.......what would be a good offer to purchase the car???? any help would be much appreciated since im new to this area
thanks alot
rvaughan1987 is offline
post #2 of 8 (permalink) Old 10-04-2009, 06:44 AM
crustysack's Avatar
you are going to have to supply a little more info- like why has it not ran in 5-10 years? stored inside or out? what does it look like? is it a rusted bucket of bolts missing everything-or is the car complete and only needs tlc?? pictures will help also
crustysack is offline
post #3 of 8 (permalink) Old 10-04-2009, 07:33 AM
#1---CHECK THE CHASSIS FOR RUST !!!!!!!!! a very common problem on the 66 gto convertible....Eric
Eric Animal is offline
post #4 of 8 (permalink) Old 10-04-2009, 08:38 AM Thread Starter
the car hasnt been run just because they never started it......it was stored in their yard for the past 5 years all tarped and covered up........the ten years prior to that it was in a garage in quincy mass......umm no rust visible on the body.....none that could be seen on the chassis.....bunch of wires hanging from under the dash......no rust in the truck...will try to get pictures soon......all the seats are good condition no rips or tears
thanks Ryan
post #5 of 8 (permalink) Old 10-04-2009, 10:31 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Sitting outside on the ground with a tarp to trap moisture is one of the worst conditions to store a car. I would venture to guess the brakes are rusted and possibly seized by now and the steel lines for them and fuel may need replacing as well.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #6 of 8 (permalink) Old 10-04-2009, 11:13 AM
grabber's Avatar
With something like that you might as well start the frame off restoration immediately. Not being able to see the car personally I would say you are going to need the brakes completely redone, the gaskets in the engine redone (you might as well rebuild the engine at that point), gas tank fuel line redone as well as the cooling system redone. Then all that stuff will have to come off again when you do a frame off, lot of work to drive a rat rod around for awhile. If your looking for something to drive now the guy I bought my 66 sport coupe from has either a 66 or 67 tri power convert for sale for about $40K.
grabber is offline
post #7 of 8 (permalink) Old 10-13-2009, 11:07 AM
You may get by with just swapping out the fuel in the tank and installing a new battery. No telling with what little info you gave.
We need pictures!!
post #8 of 8 (permalink) Old 10-15-2009, 09:13 AM
xcmac26's Avatar
Quoted: 5 Post(s)
I grew up in coastal MA and we had a 73 duster that spent it's life in a garage. Still had MAJOR rust issues. Salt air wrecks cars and MA is notorious for that. Get under the thing and poke around, wouldn't suprise me at all to find out the thing's (sadly) a rust bucket
xcmac26 is offline
Frame Question H/T vs Conv cv1970 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-08-2009 01:21 PM
Newbie 1969 GTO Conv 53 Blue Flame 1964-1974 Tempest, Lemans & GTO General Discussion 25 01-07-2009 08:43 AM
a few gto and other cars red2bunkeru 1964-1974 Tempest, Lemans & GTO General Discussion 4 02-13-2008 02:58 PM
Buying an 05 GTO from a lease?? HUNTMAN-USA 2004-2006 GTO General Discussion 11 01-01-2008 09:25 PM
buying a GTO kirks5oh 2004-2006 GTO General Discussion 4 12-11-2006 10:59 PM
