Mini starter - Pontiac GTO Forum
post #1 of 7 (permalink) Old 10-26-2011, 10:59 AM Thread Starter
Mini starter
Hello,
I took the forum advice and purchased a Summit High-Torque mini starter for my 68 gto with hot start problems. I disconnected my remote soleniod and hooked up the mini starter directly. Once I drove it for a while and got the headers nice and hot, I tried to start it back and it turned over (where before it would just click when it was hot) it did turn over slowly and eventually start. I drove it again for another 25 minutes and killed it, it would start back, but it turned over several times. Do I need to hook the remote soleniod back up or leave well enough alone. All help is appreciated. I am also going to add a heat shield. Thanks
simmons68 is offline
post #2 of 7 (permalink) Old 10-26-2011, 03:19 PM
Sounds like you're going in the right direction. Ifn' it wuz me, I'd probably put on a shield just to try to protect the starter from an early heat-induced death. As for the rest, it's up to you --- if it starts when you need it to, you're ok
post #3 of 7 (permalink) Old 10-26-2011, 05:10 PM
Check BOTH your battery cables.....positive for good connection and heat damage. Negative for the same. make sure all connections are clean and tight....Eric
Eric Animal is offline
post #4 of 7 (permalink) Old 10-29-2011, 08:18 PM
Just FYI.....the fellas on PY forum are putting together a "group buy" for some Newly designed and updated Robb Mc starters.....Great Product!!...check it out! E
post #5 of 7 (permalink) Old 10-29-2011, 11:32 PM
646904GTO's Avatar
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #6 of 7 (permalink) Old 10-30-2011, 08:55 AM
May have already done this , but purchase cables that are a 2 or 1 guage size,and buy them pre-made. Do not use the clamp-on temporary post ends !!! They do not conduct power thru the entire cable as well a factory made cable. Oreillys carrys a borg-warner(BWD) cable that can be purchased in the proper length to match what your using now,in the bigger cable size.
markdavid is offline
post #7 of 7 (permalink) Old 10-30-2011, 10:40 AM
I'm a big fan of the RobbMC starter and also the company. They build very high quality parts, and they're great to deal with - very fair-minded. I'm running one of their starters, in-line fuel filter, dual-mode fuel pressure regulator, and one of their "big" mechanical fuel pumps.
mini tub mitchrac1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-03-2018 09:01 AM
Tub/Mini-tub? What are my options GoatCity 2004-2006 GTO General Discussion 11 05-11-2013 05:44 AM
mini high torque starter for 4 speed car. auburnconsulting 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-13-2008 05:58 AM
Another Mini with the Cavalier fergyflyer Racing and Kill Forum 3 02-14-2008 10:08 AM
