My 68 tempest that I just picked up - Pontiac GTO Forum
post #1 of 14 (permalink) Old 09-12-2011, 08:09 AM Thread Starter
Found a 68 tempest on craigslist. Body looked straight with very little dings. 400 motor, b&m shifter and I'm hoping there's good hearings in here, I was told this was used on a strip.
Motor was never started since 97 , but was told that it still was running before they stashed it. Anyone got ideas on what the first steps are? Drain gas? Dump oil? Rebuild carb?
Inda_bebe is offline
post #2 of 14 (permalink) Old 09-12-2011, 08:14 AM Thread Starter
Notice a gap on the grill and fender, why do you think it isn't lined up?
No fender wells
post #3 of 14 (permalink) Old 09-12-2011, 08:34 AM
jetstang's Avatar
Nice score! Congrats.
Drain the gas tank and clear all the lines. I would run it off a gas can first, then do the tank later.
Drain/refill oil, rebuild carb and clear out the sediment.
Check/change plugs.
Me- I would make sure the oil looks good, throw a battery in it, then see if it turns over. If it does, let it crank for 10-15 seconds to get some oil moving, make sure it has oil pressure. Then, dump some gas down the carb, ounce or so and see if it fires up. If it runs at all then you know the ignition works. This will also tell if they are lying and the motor is blown or it has a spun bearing, thus making all maintenance a waste of time. If it runs, then do all the maintenance stuff above. If it doesn't turn over, then put a big wrench on the crank and see if the motor turns at all. If it still doesn't, then pull the plugs and try again.
Good luck, hope it cranks right up.
Burning rubber since 1982!!
jetstang is offline
post #4 of 14 (permalink) Old 09-12-2011, 08:50 AM
68greengoat's Avatar
As far as the gap between the fenders and bumper, that's correct. Your just missing the filler pieces....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #5 of 14 (permalink) Old 09-12-2011, 11:00 AM Thread Starter
Check/change plugs.
those steps are perfect. im gonna start as soon as i get time. thanks for the tips and welcome.
post #6 of 14 (permalink) Old 09-12-2011, 11:02 AM Thread Starter
thank God. i was already thinking that it still wouldnt line up if i pushed it back a bit. how are is it to find these trimmings, what what should i call it when searching? front bumper trimmings?
post #7 of 14 (permalink) Old 09-12-2011, 12:08 PM
First thing you need to do is remove those stripes!!!
post #8 of 14 (permalink) Old 09-12-2011, 12:28 PM Thread Starter
for sure, lol. i was wondering what he was thinking when i saw it for the first time. this dude used it for drags, hope it has a posi in it. but i definatley need to start looking for INTERIOR, this was looking like ****. what other car make and models fit for back and front bucket seats?
post #9 of 14 (permalink) Old 09-12-2011, 12:42 PM
It's called a "grill to fender seal" in OPGI's catalog( Chevelle Parts, Chevelle Restoration Parts & Accessories, El Camino Restoration Parts & Accessories, Restoration Parts, Monte Carlo Parts, GTO Parts, Cutlass Parts, Skylark Parts, Cadillac Parts | OPGI.com ). $61.95 for the pair. Other vendors may have them too, Ames YearOne etc....
SOLD.....
462ci, 4spd
post #10 of 14 (permalink) Old 09-12-2011, 10:51 PM Thread Starter
is there another grille that i can use that would eliminate the use of the trimmings?
Picked up the GTO gmantheman 2004-2006 GTO General Discussion 0 05-15-2011 12:52 AM
Picked up my new GTO! tabes117 Member Introductions 12 01-02-2007 10:52 AM
Just picked up an 05 miltownsho Member Introductions 2 09-24-2006 10:08 PM
Well I just picked it up! Borsig Member Introductions 8 02-01-2006 07:08 AM
new here....just picked up my 04 GTO razors 2004-2006 GTO General Discussion 7 11-11-2004 11:08 AM
