My 69 gto is different, why - Pontiac GTO Forum
post #1 of 13 (permalink) Old 06-15-2011, 01:43 PM Thread Starter
There is something extra on my front bumper and I dont know why, it looks like my front bumper is extended out further with 2 inch "bumper to fender" rubber pieces on both sides of the fenders BUT also there is a rubber piece on top that is from one fender to the other on top, its almost like they were trying to extend the nose out farther. I had searched the internet and none other 69GTO has this so id like to know why this particular car has this?
Here is an example as you can see on the sides there are rubber pieces but "I didn't put it on in this photo but its easy to see" that extension between the hood and the front bumper there is a rubber piece that I have that's supposed to be put there so that the front nose can stay extended out longer. Does anyone know why this GTO is different?
http://i228.photobucket.com/albums/e...h/101_1845.jpg
Troopermanaic is offline
post #2 of 13 (permalink) Old 06-15-2011, 01:52 PM
that is not factory. it looks like someone designed that to cover up a bad fit.
freethinker is offline
post #3 of 13 (permalink) Old 06-15-2011, 03:23 PM Thread Starter
possibly, ill have to take the nose off to see if I can refit it then.
post #4 of 13 (permalink) Old 06-15-2011, 05:01 PM
Someone ran out of patience and hodge podged it. The Firebird look.
Once you remove the bumper you may find why it was done that way.
post #5 of 13 (permalink) Old 06-15-2011, 05:12 PM
Quoted: 23 Post(s)
yep, my 69" firebird had gasket moldings where the endura met the fender and talk about hard to align...take the bumper off and have someone help dry fit it and find out where your problem is...if something in the frame or radiator support is off it will throw the bumper fit off. in 66 the used a octagon washer that you turn to lock to the frame before tightening and it is supposed to keep it from sagging i guess.
Instg8ter is online now
post #6 of 13 (permalink) Old 06-16-2011, 01:07 AM
Sumpin's most definitely all whomper-jawed there... The bottoms of the front fenders should follow exactly the contour of the bumper and not be sticking out like they are.
post #7 of 13 (permalink) Old 06-16-2011, 05:25 PM
lewy222's Avatar
Pick a weekend when you have lots of time and lots of patience! It looks like the fenders might need some adjusting too. My guess is you will have adjusted about everything north of the windshield before you are done!
lewy222 is offline
post #8 of 13 (permalink) Old 06-16-2011, 05:35 PM
Yeah, it looks like the front fenders are not attached to the front valance.
There is quite a bit of adjustment on the front bumper brackets, you should be able to line that up. It's really a two (or three!) person job to do it right without damaging any paint. You can mask the edges of the fenders and Endura bumper to prevent damage also.
post #9 of 13 (permalink) Old 06-17-2011, 02:41 PM
Definately off kilter there. I know the chrome noses had a rubber "seal" for them, but it doesn't really look like that's it though.
DarthBubba is offline
post #10 of 13 (permalink) Old 07-07-2011, 01:32 PM
Pontiacpurebrred's Avatar
69 Custom-S .... same thing?
So I had been meaning to find this thread, I remembered it from a few weeks ago. My Custom-S has this rubber gasket as well. And not to argue with anyone, but it certainly looks like a factory item, perhaps meant for the chrome bumper and not the endura, They are made to pop into the holes at the ends of the fenders and they are factory level craftsmanship. They are supposed to be there, just not sure in what case or application.
Pontiacpurebrred is offline
