is my oil color a problem? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-04-2013, 10:18 AM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
Hi gang...
I first changed my oil on my "new" engine after 20 miles or less , just to be rid of the assembly lube, it was nasty pink.
I just changed it for the 2nd time, after 250 miles. on the stick i see what appears to be very small 'particles(?) of what kinda looks like rust.
In the light of my led flashlight, the oil pouring out of the oil pan seems to be kind of an 'olive' color.....
what gives?......
ps (it runs perfectly) me hopes me is not screwed
thanks as always
Tk
Topkat is offline
post #2 of 6 (permalink) Old 05-04-2013, 11:34 AM
Quoted: 98 Post(s)
Post a pic of the end of the dipstick with oil on it on a paper towel/napkin so we can look at it. Probably nothing, as oil is high in detergent, keeps solids in suspension, and you're putting this car back in service after a long period of time. Are you sure you didn't spill any Woodford's Reserve in the oil filler?
post #3 of 6 (permalink) Old 05-04-2013, 12:44 PM Thread Starter
Topkat's Avatar
Fresh out of Woodford Uncle Geeter......however, some Makers Mark 47 is taking it's place 'till Goat and wifey and I made a run sunday to the newe BevMo in Bellingham sunday
Hope you are well sir!
ID:	20090   Click image for larger version
Topkat is offline
post #4 of 6 (permalink) Old 05-04-2013, 02:10 PM
Quoted: 98 Post(s)
I see pink, but no particles. You could run it another 500 miles or so and change the oil and the filter. I think you have residual assy. lube in the engine....it shouldn't hurt anything. Engine oil has a natural 'olive' hue in certain lighting conditions....normal.
post #5 of 6 (permalink) Old 05-04-2013, 02:45 PM
You may want to drain the oil thru a strainer and disect the oil filter on the next 500 mile change and see if you have any metal particles in the oil or filter.
05GTO is offline
post #6 of 6 (permalink) Old 05-04-2013, 04:57 PM Thread Starter
Topkat's Avatar
Whew! thats a relief.....
rock on men
Topkat is offline
horrible problem!!!!!!Oil pan bolt missing!!! TeHKasperek Service, Maintenance and Technical Discussion 9 06-07-2011 06:49 PM
Recent oil change n seems like oil level creeps higher?..... pctek Service, Maintenance and Technical Discussion 2 09-27-2010 09:58 PM
Oil pressure gauge problem Richie Cat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-26-2008 04:16 PM
Oil Change Problem btchplz Service, Maintenance and Technical Discussion 21 08-24-2008 10:33 PM
Check oil display problem SANDU002 Engine Discussions 3 10-10-2006 09:12 PM
