Mystery gas smell - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-02-2013, 06:32 PM Thread Starter
rentalguy1's Avatar
Mystery gas smell
The car has a strong gas odor when driving. It is worse at higher RPM's. There is no obvious leaks, and there are no wet spots under it. I am guessing that the carb is loading up when the accelerator is moderately applied under a load. I'm not a carb expert. Is this possible, is there a way to check for this, and what would cause it? It is a factory reman'd Quadrajet 4bbl that was put on when the engine was rebuilt about 12 years/4,500 miles ago.
rentalguy1 is offline
post #2 of 6 (permalink) Old 11-02-2013, 07:26 PM
Red1970GTO's Avatar
Smell
Assuming it's the pictured GTO... Crawl under the rear and check out the vent on the front of the gas tank. The hoses can get clogged with dirt/debris.
What have you changed on the car lately? A changed part is the usual suspect.
Red1970GTO is offline
post #3 of 6 (permalink) Old 11-02-2013, 08:20 PM Thread Starter
rentalguy1's Avatar
Thanks. It is the one pictured. Other than the oil, and it actually being driven a little rather than sitting in the garage nothing has been changed. I'll check the vent hose in the morning. Didn't think about that.
post #4 of 6 (permalink) Old 11-02-2013, 09:26 PM
Red1970GTO's Avatar
Smell
Did you check the return fuel line rubber?
post #5 of 6 (permalink) Old 11-03-2013, 09:17 AM Thread Starter
rentalguy1's Avatar
Only visually under the hood while looking for wet gas. It never occurred to me to look behind the engine bay because of the way it's presenting. I'll get out there and check it in a bit. I'm being a little lazy this morning.
post #6 of 6 (permalink) Old 11-03-2013, 08:38 PM Thread Starter
rentalguy1's Avatar
The lines were good. Looked closer at the carb and two of the mounting nuts were loose. I retorqued them and it seems to have solved it. Thanks for the responses.
68 GTO Gas smell joedee 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-29-2013 07:36 AM
Smell Gas Kingfreeze21 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 05-17-2012 01:48 PM
Mystery Manifold gary4278 Intake and Exhaust Discussions 0 11-04-2011 09:14 PM
A.I.R mystery Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 7 02-13-2011 02:22 PM
