Need advice converting an Turbo 400 auto tranny to a manual tranny - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-14-2012, 08:33 PM Thread Starter
Has anyone on this site converted an auto tranny to a 4 or 5 speed? Iím seriously thinking about this for two reasons. 1) It would be more enjoyable to drive with additional control and improved gas mileage and 2) Iím fed up with consistent transmission leaks ever since the year I bought this vehicle (1979) in spite of a complete rebuild (20 years ago) and whatever gaskets I replace.
Currently this 67 GTO has a Turbo 400 auto tranny with the shifter on the tree from the factory. Many folks on this forum would say ďkeep it originalĒ, but this is not a priority for me right now. Iím very serious about making this conversation and ready to drop the money on this project. This is a project I chose to do on my own. I believe the transmission swap and drilling through the floor board for the shifter should not be too much difficulty. However; the clutch install may be somewhat challenging. Iíve heard (and researched) that there are hydraulic clutches available that make an install almost painless. Anyone have input on this?
Thanks in advanced.
Jim
jimmy328 is offline
post #2 of 3 (permalink) Old 09-15-2012, 09:51 AM
post #3 of 3 (permalink) Old 09-16-2012, 04:35 PM
66goatframeoff's Avatar
z bar mount
Man clutch not that big of a deal to install although hyd would be nice but costly ck to see if the Z bar frame mount is in place if not they are available and you can weld it in I just swapped mine back to fact 4 speed from t-400 just took a little time to get all pieces together but install is a breeze you can convert your auto pedal to 4 speed if you decide to go that way my only issue is figuring out the position of the tunnel cover has had the floor pan replaced with auto hole and shifter position is critical with a console any question let me know went with alum flywheel had clutch built by local shop .
66goatframeoff is offline
Manual Tranny Question 64tempestct Drive train, suspension, alignment and brakes. 2 03-28-2012 09:08 AM
64 Lemans with a 400 auto tranny to manual Seol21 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-16-2011 08:31 AM
4 speed manual tranny 67 gto, were?? HELP?? 350LT1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 03-06-2011 09:58 AM
Any tricks to install manual tranny? oldtexasgoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 06-19-2008 01:28 PM
Manual Tranny anyone? Integraoligist 1964-1974 Tempest, Lemans & GTO General Discussion 2 10-17-2005 11:14 AM
