Need Advise - Pontiac GTO Forum
post #1 of 9 (permalink) Old 02-23-2011, 09:08 PM Thread Starter
Need Advise
I'm picking up a 1964 Pontiac lemans has the orginal 6 & tranny . Also comes with a 389 & tranny rebuildable , Or i was thinking pro streeting it , I'm kinda up in the air right now. Could use some advise . Frame is solid , it no longer has the bench seat.The second owner dropped some buckets in it . All & All it's solid.
Thanks,
Joe
SL64 is offline
post #2 of 9 (permalink) Old 02-23-2011, 09:36 PM
If you are looking at this as an investment, restore it to original.
Otherwise, have fun and do what you want with it.
just my opinion.
Russ
russosborne is offline
post #3 of 9 (permalink) Old 02-23-2011, 09:57 PM
just my opinion.
Russ
Make yourself happy first. It's your money and your car...
If you want to go original, well, then it's just a matter of finding the right parts and doing the work. If you want to build it with some "cojones" well, we can help with that...
post #4 of 9 (permalink) Old 02-23-2011, 10:51 PM Thread Starter
I'm going to run down to my local chassis shop & have a chat ,It's right around the corner & see if it's worth it. My x Bro in law ( still in good terms) owns a body shop so paint & the lower rear q's are not a problem. Just don't know if i want to start cutting up a 64 lemans , if ya know what i mean.
Joe
SL64 is offline
post #5 of 9 (permalink) Old 02-24-2011, 07:40 AM
One can build a SERIOUS street machine without 'cutting up" the car. Most of the performance parts available are intended for installation in unmodified cars. If all the stuff is "bolt-in", you won't harm the integrity of the car.
Be sure you're aware, there is no "need" for anything but a Pontiac V8 today. ALL the "goodies" for a hotrod engine are readily available, and easily puts the Pontiac "out of reach" of a small block, and it takes a WHOLE LOT of "big block" to make the kind of streetable power the Pontiac can make. Many will "bend your ear" to put a Chevy in it. They're "scared" of the Pontiac when "done right". 600 HP on 93 is a "slam dunk" today. And they are as or MORE reliable than an equal BBC.
A LeMans or Tempest doesn't command the resale value GTO does.
FWIW
Jim
Mr. P-Body is offline
post #6 of 9 (permalink) Old 02-24-2011, 06:32 PM Thread Starter
Thanks guys i appreciate it. I talked to the guys at the race shop today.
Going with a mini tub & will retain the rear seat . Going to have the 389 & tranny rebuilt .
Joe
SL64 is offline
post #7 of 9 (permalink) Old 02-24-2011, 09:12 PM
Quoted: 23 Post(s)
welcome to the herd, sounds like it should be a fun project. you will be able to get some meats in there with the mini tub, and that 389 will give it plenty of get up and go. I am sure Mr. P-body can lay out a good plan for that motor, don't let a chevy guy pick your parts....
Instg8ter is online now
post #8 of 9 (permalink) Old 02-24-2011, 10:06 PM
It'd be well worth your while to double-check whatever the race shop recommends with Mr. P-Body and the other folks here.
post #9 of 9 (permalink) Old 02-25-2011, 09:15 PM Thread Starter
I'm Pontiac all the way.
SL64 is offline
Any advise on Points? POOF 1964-1974 Tempest, Lemans & GTO General Discussion 10 05-03-2008 07:10 PM
Please advise GOATbreath 2004-2006 GTO General Discussion 14 03-24-2008 08:50 PM
Need some advise 04YJ-GTO Exterior Discussions 6 03-01-2008 03:16 PM
Need Some Advise warmongoose66 2004-2006 GTO General Discussion 58 02-03-2008 12:59 AM
Newbie Here and need some advise Richdawg192 Intake and Exhaust Discussions 6 02-02-2008 10:58 PM
