Need car checked in PA - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-16-2012, 04:13 PM Thread Starter
Tambo's Avatar
I need to get a car (not Pontiac) checked out near Pittsburg PA, can anyone recommend an appraiser in that area?
Tambo is offline
post #2 of 3 (permalink) Old 09-18-2012, 07:02 AM
joesweeting's Avatar
I used United Appraisals. They did a horrible job. I was told the engine was good to go, but the transmission will need work. It was the opposite. When I received the engine it had a spun bearing. Also in the report it stated the parking brake worked as designed, but it was not even hooked up. The floor pans had been replaced but not welded they where riveted in place. There were several areas of damage that were not documented. I called and asked and they stated the owner could have switch the engine and disconnect the parking brake after inspection. They did not have a lift available so they stated they could not do a detailed inspection of the under carriage.
Sent from my DROIDX using AutoGuide.Com Free App
joesweeting is offline
post #3 of 3 (permalink) Old 09-19-2012, 06:57 AM Thread Starter
Tambo's Avatar
Thanks Joe.
As it turned out the seller didn't check out so the deal's off.
Tambo is offline
So I checked to see if I have a matching numbers car today... SixTeight 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 15 04-28-2011 08:47 PM
Goat under warranty, new owner thing to get checked Nreuter87 Service, Maintenance and Technical Discussion 5 04-13-2009 06:04 PM
Getting Alignment Checked GM Kid Drive train, suspension, alignment and brakes. 12 03-31-2006 11:28 AM
Checked out a 2004 GTO today... GTO For Life 2004-2006 GTO General Discussion 5 09-13-2005 03:45 PM
