Need Help-- '65 Lemans GTO advice - Pontiac GTO Forum
post #1 of 17 (permalink) Old 06-30-2013, 10:36 PM Thread Starter
Hello all,
I am looking for some advice from some experts/owners/anyone with experience dealing with the 65 GTO. I have my eye on one but wanted to run it by y'all and get some advice.
The car is a 65 Lemans hardtop coupe with the GTO package (the 5NW on the accessory plate confirms this.) The man says it came with factory air, 4-speed manual transmission, and standard 6.5 litre 389. The car is in good shape, one previous owner, 104k miles, only a little surface rust in places, and runs very well. The man says nothing in the engine has been replaced except the carb, and he has the 'original' but it is not a Tripower setup. All original documentation comes with the car including the original bill of sale and window sticker. Also, the original owner had the rear end taken out and replaced with another unknown part but the original rear end is with the car.
He bought it for $20k and is looking for a little bit more. Please reply with any advice, discussion, etc. Its a beautiful car and would love it if it all checks out and the price is right.
eloughlin is offline
post #2 of 17 (permalink) Old 07-01-2013, 05:04 AM
Koppster's Avatar
Pictures would help...
Koppster is offline
post #3 of 17 (permalink) Old 07-01-2013, 07:13 AM
SANDU002's Avatar
5NW on the data tag confirms it is a GTO not a Lemans. PHS would also confirm it is a GTO.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #4 of 17 (permalink) Old 07-01-2013, 03:01 PM Thread Starter
Here are some pictures. Part of the accessory plate was blocked by a relay so I couldn't get the 5NW part in the picture. However I have seen it and it definitely is on there.
post #5 of 17 (permalink) Old 07-01-2013, 09:33 PM Thread Starter
18 year old son-first GTO
To all, this is the dad!
This post was made by my son, who is 18 and like the title says is looking at his first GTO. We've done a '47 Willys CJ2A and now venturing back onto the street!
His interest is getting a fair price for this car, and learning about GTO in the process. Any help you all can give us would be greatly appreciated.
Only problem is he's not going to get a lot of use out of it for a few years as he is starting an US Air Force scholarship next month and will be heading out to the Air Force Academy for 4 years this time next year!!
Guess who gets to keep the battery charged up while he is away
We have a few additional questions:
What is the 23-2 stamped on the bottom right of the body tag in the optics above?
How desirable is 4sp, 4bbl, 389, factory air, ps, pb, and even has the funky verbra-sonic switch?
We are working on checking engine numbers, axle numbers, trans numbers next. Mainly for our interest, as this is just going to be a cruise/driving car..not looking to rack up trophies..
What other areas should he be concerned?
Thanks in advance to all who respond, he will really appreciate it..I know I will too.
Dad
post #6 of 17 (permalink) Old 07-02-2013, 06:37 AM
Sir, I think the car is excellent. I think your son should buy it. Even better that you get an opportunity to maintain it for a couple years. Make sure it is something you wouldn't mind owning, because his priorities will likely change over the next few years. My guess is the 2017 Corvette will have some of the technology being used in the Joint Strike Fighter today. Congratulations to the son on the appointment to a US service academy and thanks in advance for your service to our nation. Matt
Matthew is offline
post #7 of 17 (permalink) Old 07-02-2013, 08:50 AM
68greengoat's Avatar
A highly optioned 4 speed? It sure would be desirable. As Sand said, get the PHS to verify the car is what is being claimed. Just send/fax the vin to PHS Historic Services , they will send/fax(depending how fast you need the info) info on what options the car left the factory, including if it had the GTO option. Data plates can be reproduced... Have you verified the engine is a '65? There is a date code by the dizzy, should look something like F165. The last digit being the year........
Sorry, can't help with the 23-2
Any more pix of the exterior???
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #8 of 17 (permalink) Old 07-02-2013, 09:18 AM
Quoted: 105 Post(s)
There is an extensive amount of information regarding '64-'65 data plate informaiton on the Performance Years forum. You can find out pretty much all you need. X2 on the PHS documentation. Depending on the manufacturing plant, the 5NW may or may not mean it's a GTO. Trust, but verify!
post #9 of 17 (permalink) Old 07-02-2013, 03:55 PM Thread Starter
More numbers!
Just back from car...here's what we have so far:
Looks to be a Pontiac, MI build.
Block number 9778789 so that seems to check
Big "C" on dist pad so that must mean March
Got to clean a little more back there for DOM, and YR
Engine Code in front: WT
Number there: 553686 but did not know to look for third set..so don't know if this is production number or engine VIN number (does this match number on firewall tag or doorframe tag?).
For grins and giggles: Alternator number is: 10069255
What do yall think all the numbers are matching up on this car?
post #10 of 17 (permalink) Old 07-02-2013, 04:57 PM
rickm's Avatar
Quoted: 5 Post(s)
gto was a lemans option in '64 n 5.
rickm is offline
New 66 Lemans owner would like advice TheGoat66 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 08-27-2013 01:27 PM
70 Lemans Engine Swap Advice VT Lemans 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 03-07-2010 10:24 PM
back again after a long break - need more purchase advice 72 lemans jasonmrenda 1964-1974 Tempest, Lemans & GTO General Discussion 15 04-23-2009 06:12 AM
