Need help identifying tools. - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-02-2018, 08:29 PM Thread Starter
RMTZ67's Avatar
Quoted: 62 Post(s)
So i bought a nice cache of tools for $30 this weekend. can't believe the post was up for 29 days for $40. Got a ridge reamer, three different types of valve spring compressors, honer, craftsmen pneumatic grease gun, piston ring compressor. plus these four unknown tools. Anybody know what those tools pictured in the second pic are for?
ID:	115687   Click image for larger version
RMTZ67 is offline
post #2 of 3 (permalink) Old 10-02-2018, 09:02 PM
Tool on the far right is, I believe, a piston ring groove cleaner. That "wheel" with the different square/rectangular protuberances on it has the different sized dies to fit into different width ring grooves. Not sure about the others.
post #3 of 3 (permalink) Old 10-03-2018, 02:21 PM
joelau27's Avatar
The two on the left are drum brake tools for removing springs. The picture on the left: starting at the top is a pair of tin snips, next is a cylinder hone, then it looks like a valve spring compressor, next a piston ring compressor, then these last two look like small engine tools. One might be a valve spring compressor, I don't know what the other is, sorry
Joe
joelau27 is online now
Trim removal tools and other specialty tools for restoration 1972GTOWW5 1964-1974 Tempest, Lemans & GTO General Discussion 1 10-09-2017 07:17 PM
Need help identifying this sensor. skapegoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 06-16-2011 07:32 AM
Need help identifying a transmission ghad14 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 10-02-2010 08:41 PM
need help identifying a 1972 gto as authentic aceofpa1 1964-1974 Tempest, Lemans & GTO General Discussion 2 12-21-2008 01:28 PM
Changing transmission and diff fluid - What tools do I need? 04m6_ca Service, Maintenance and Technical Discussion 1 09-29-2005 10:20 AM
