New Battery Cable - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-23-2013, 08:15 AM Thread Starter
Oldeboy's Avatar
New Battery Cable
I just replaced my battery cables on my 1970 with one from Ames with the asphalt weave on the outside. After the car ran for a few minutes there was some wisps of smoke coming from this area engine. (not exhaust smoke)
Do these new battery cables with this asphalt weave typically smoke a little when new?(first few times getting hot)
Yes the wire is running through the metal sheath. I painted the metal sheath with black 900 degree caliper paint as it looked a little rough.Any thoughts? Thanks
Oldeboy is offline
post #2 of 3 (permalink) Old 03-23-2013, 09:46 AM
Not sure what gauge your battery cable is but unless you have a serious short the cables typically would only get marginally warm after starter has been run. If you noticed smoke after the engine has run it is most likely heat from the exhaust manifold transferring heat to the conduit. I would consider the newly painted metal conduit (even though it is high heat paint, some volatiles still have to 'burn off') or the asphalt sheath or combination of both.
PS. I do not know if the conduit was originally painted in 70, my 65 is looked to be cad plated, this helps to reflect heat vs dark paint absorbing heat.
olde-goat is offline
post #3 of 3 (permalink) Old 03-23-2013, 10:15 AM
Quoted: 105 Post(s)
I wouldn't worry about it. I have the same cable from the same supplier, and the weave is starting to unravel a bit at the top, but it won't burn.
What style battery cable is correct? 70conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 07-16-2012 10:11 AM
battery cable tube Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 9 07-07-2011 04:14 PM
Battery Cable Ground injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-02-2010 08:54 AM
