new heater core - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-10-2017, 07:34 PM Thread Starter
Quoted: 33 Post(s)
new heater core
This is on a 72 with a/c , but I assume all will be similar. Does the heater core go in the box with no seal first against the core? It seams the core would have metal to metal chaffing as you screw the clamp bands to tighten it in.
tjs72goat is offline
post #2 of 5 (permalink) Old 08-11-2017, 08:59 AM
1968gto421's Avatar
Quoted: 72 Post(s)
I believe from 1967-1972 they are all very similar. There are several guys here who have dine heatercores/boxes. Hopefully they will chime in with their expertise.
Here's a thread that may be helpful----- https://www.gtoforum.com/f50/71-leman...re-swap-30240/
Best of luck!
1968gto421 is online now
post #3 of 5 (permalink) Old 08-13-2017, 07:19 PM Thread Starter
Quoted: 33 Post(s)
Thanks for the response. This is what may confuse me from that and what I see.
NOTE: Be sure the core to case sealer is intact before installing core. Use new sealer if necessary.
Is this part of the new heater seal kit I ordered? It seemed odd when I mocked up the install, that the heater core would fasten against metal. Maybe prematurely chafing a hole to leak.
post #4 of 5 (permalink) Old 08-14-2017, 10:59 AM
1968gto421's Avatar
Quoted: 72 Post(s)
You might try sending a PM to MEANGREEN71 and since he has done this job, he probably can answer your questions.
post #5 of 5 (permalink) Old 08-14-2017, 07:32 PM Thread Starter
Quoted: 33 Post(s)
I called Ames Engineering today and they cold find nothing in their books. I had a roll of paper gasket material and decided to make a picture frame square where the heater core meets the metal box as a cushion against metal to metal chaffing.
New Heater Core mysweet67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 04-20-2014 10:13 PM
68 heater core 1coolduck 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-01-2014 08:26 PM
65 GTO Heater Box Heater Core Blower Motor Questions WideTrack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-06-2013 07:45 AM
'67 heater core Crikker 1964-1974 Tempest, Lemans & GTO General Discussion 16 11-29-2009 07:59 PM
69 Heater Core ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-03-2009 06:42 PM
