New M22 - 4th Gear Grinds - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-27-2013, 04:58 PM Thread Starter
Hi,
I recently purchased an M22 to replace an original M20 in my 1967 GTO. It shifts fine under normal driving conditions, however, when I get on it and am going through the gears quickly (taking it to red line), I noticed that 4th gear grinds a little and after it goes into gear, it makes a high pitched winding noise almost like something is still spinning extremely fast. It is only this gear that this occurs in and only happens when I get on it.
I intend to contact the guy I bought it from (it does have a warranty), but would like to hear from others about possible causes. I don't think it is my clutch, otherwise all gears would grind, possibly a synchro? If so, why only at high RPM's?
Thanks,
Tony
Beefcake77 is offline
post #2 of 5 (permalink) Old 10-27-2013, 05:07 PM
Quoted: 105 Post(s)
Worn synchro in 4th gear.
post #3 of 5 (permalink) Old 10-27-2013, 06:42 PM Thread Starter
Possibly, but how could that be? It has less than 200 miles on the transmission. Does that imply that it was not built correctly?
post #4 of 5 (permalink) Old 10-28-2013, 02:04 PM
Quoted: 105 Post(s)
Yes. The synchro assembly could be defective or installed incorrectly. It needs to come apart for inspection to determine the condition of the parts.
post #5 of 5 (permalink) Old 10-28-2013, 06:13 PM Thread Starter
OK, thanks for the feedback. I will respond back with the outcome as the story unfolds.
Proven cam grinds for the LS2s? Iron Indian Engine Discussions 1 09-23-2011 08:49 AM
4th gear issue please help Zdeuce4 Drive train, suspension, alignment and brakes. 4 07-01-2011 12:03 AM
Gear box 4th to 3rd ameriscot Drive train, suspension, alignment and brakes. 5 11-02-2007 09:41 PM
Swapping out the 3sp for an M22 4spd jim's68 1964-1974 Tempest, Lemans & GTO General Discussion 1 06-16-2006 08:52 PM
