New Member w/Question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-12-2011, 09:02 AM Thread Starter
Hey everyone- I'm Matt and just joined the site a couple of days ago. Question for fellow GTO enthusiasts regarding cooling. I have a 67 GTO, 400 bored & stroked to a 462, factory Quadrajet, intake, heads (heads have been worked on), factory exhaust manifolds, 3.55 rear. etc. Compression is in the mid 9's. Car runs great; however, it loves to run at about 205-210 degrees F on the highway. On cooler days (temps in the 60-70 degree range) she'll run around 185 @ 60 mph. Anything warmer and she shoots to the higher temps. I've had people tell me that's normal, others tell me that's high. I also have the factory radiator and I believe a 180 degree thermostat. I don't want to put an aluminum radiator in it because the engine (and bay) is stock appearing. Any opinions?
67HardTop is offline
post #2 of 3 (permalink) Old 10-12-2011, 12:10 PM
Quoted: 102 Post(s)
That's pretty much normal and not a concern. If you check out the threads on temps, you'll find that out. You're running a lot of cubes on a stock radiator, and you're not overheating. Stock, these cars can run 205-215 going down the road on a hot day. I've driven these cars since the '70's, and that's pretty normal, especially with a lot of cubes. New cars run at 220-230 as normal operating temp all day long. 200 degrees will not hurt a thing....running 160 will, though. Relax and enjoy your car.
post #3 of 3 (permalink) Old 10-13-2011, 03:55 PM Thread Starter
Thanks- appreciate the information.
New Member with GTO question. radarfxr 1964-1974 Tempest, Lemans & GTO General Discussion 6 10-18-2008 07:00 AM
New member with a what is it worth question Mac66 1964-1974 Tempest, Lemans & GTO General Discussion 8 02-19-2007 03:21 PM
New Owner/ New Member but a simple question edysinger 2004-2006 GTO General Discussion 19 12-02-2005 09:19 PM
New member question dmercado_gto Member Introductions 11 12-02-2005 04:03 PM
new member with question Lorrie Ann 2004-2006 GTO General Discussion 3 10-18-2004 11:12 AM
