New Owner Question - Pontiac GTO Forum
post #1 of 11 (permalink) Old 05-31-2014, 09:09 AM Thread Starter
New Owner Question
I just bought myself a "driver" quality 1969 GTO a week ago. It is my first that I own. As I am going through it, one of the things that it needs is a new radio. The stock AM radio doesn't work at all.
I am looking for some recommendations... I have used Retrosound before but I am wondering if there are other better choices. Also, there seems to be only a speaker in the dash top and none by the kick plates nor rear deck. If I add speakers, I would like to know what some of the factory placement options were so I can try to be faithful to that.
Thanks for any help you can provide!!!!
saturnkk is offline
post #2 of 11 (permalink) Old 05-31-2014, 10:07 AM
pjw1967's Avatar
Can't speak directly to a '69, but my '67 radio doesn't work either. If you crawl into the trunk you should be able to see if there are speaker cutouts in the sheet metal under the package tray. I don't think there were any in the door panels. If you have a smartphone, an option that people are pursuing is a Bluetooth speaker.
pjw1967 is offline
post #3 of 11 (permalink) Old 05-31-2014, 12:30 PM
maktope's Avatar
There is after market speakers that go in the floor vents. For stereo what i did was mount a 10 disk changer in the trunk, then a standard CD player in the consol bracketed by foam. ran the wires from it under the consol then under the carpet. Unless you really look you cant notice it. I have the original radio still in dash just it doesnt work. Not sure if this is an option you want to go with or not. There is also a company ill find the link that makes 1inch balls that mount ontop of the dash in the corners budy has it on his 66 malibu sounds good but once you notice them you cant help but notice them. Also mine is a 69
maktope is offline
post #4 of 11 (permalink) Old 05-31-2014, 04:17 PM
Welcome saturnkk.....
I too had the same problem. I have a 68 Lemans/all GTO under the skin. RA III w/3:73 gears and 400 auto.
I have a thread about this if you research it. My suggestion though, NO CUTTING!
I like to do cruising with some good tunes (Beach Boys) so I put in a quality radio w/ 4 three way speakers, 7 band EQ and a 160 watt amp with a 12" woofer. EXCELLANT SOUND!
Good luck
68lover is offline
post #5 of 11 (permalink) Old 05-31-2014, 07:46 PM
69GTOCONVLOVER's Avatar
Hi Saturnkk; we just went with a direct fit am/fm/aux-in year correct looks radio in my 69. Stored the working original am radio. Decided to converse the center speaker into 2x 4" speakers and two more behind the covers over the kick plates (speaker covers were there but no speakers or wires). Works great and we hook up ipod and smart phone.
ID:	40218   Click image for larger version
ID:	40226   Click image for larger version
ID:	40234   Click image for larger version
ID:	40242   Click image for larger version
69GTOCONVLOVER is offline
post #6 of 11 (permalink) Old 06-01-2014, 04:12 AM
Did you get that from Ames or Performance years ?
75tntrv is offline
post #7 of 11 (permalink) Old 06-01-2014, 05:26 AM
75tntrv, I got it from OPG.
post #8 of 11 (permalink) Old 06-01-2014, 07:46 AM
Thanks did not know opg had that style.
75tntrv is offline
post #9 of 11 (permalink) Old 06-01-2014, 08:01 PM
jmt455's Avatar
If you are looking for a low-cost solution that looks stock, you can also just add an AUX input to the AM radio.
The Delco radios can (usually) be repaired inexpensively.
I just had my AM-FM mono repaired and I added an aux input. The cost was under $90.
Add a factory fader, with front & rear speakers in the OEM locations (center of dash and rear deck) and you've got cheap tunes.
You can get the required 10 ohm speakers here:Classic Car Speakers
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #10 of 11 (permalink) Old 06-04-2014, 10:31 PM
67GTOCoop's Avatar
I purchased the Model Two radio from Retrosounds and I really like its functionality paired with its old school looks. I'm putting 2 3.5" speakers in my dash, 4" components in the doors, and am trying to decide on what to do with the rear. . . . I know I want to do at least one sub in a box under the package tray but I would like to do 2 10" subs if possible. I am also debating on putting some sort of speakers in the rear package tray but was curious what others have tried. I thought about mounting two 6X9s on the top of the sub box but I dont want too much going on. Im still pretty undecided. . . .
67GTOCoop is offline
Header question for MA owner FitzysGTO Intake and Exhaust Discussions 3 03-13-2014 02:25 PM
New owner with a newbie question. Blubaru 2004-2006 GTO General Discussion 3 11-10-2012 10:54 AM
gas question for a new owner my66 1964-1974 Tempest, Lemans & GTO General Discussion 1 04-29-2011 07:09 PM
New Owner and question. Aceofaces 2004-2006 GTO General Discussion 7 09-19-2006 09:02 PM
New owner and pedal question xp800 2004-2006 GTO General Discussion 10 10-03-2004 06:10 PM
