New rear package tray install advice needed - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-13-2011, 04:31 PM Thread Starter
gotyorgoat's Avatar
Does anyone know if I need to remove the back seat in order to install a new rear package tray? I am not sure what to do with the cloth flap on the front of the tray other than to remove the seat and tuck it behind the back rest. Does it need to be glued down? No directions were included with the part.
I found an older post about removing the rear seat so I think I can figure out how to do that.
gotyorgoat is offline
post #2 of 2 (permalink) Old 09-13-2011, 05:09 PM
Quoted: 103 Post(s)
No glue required. The seat will hold the flap in place. You need to unclip the seat and slide it up a bit to tuck the flap in, then slide the seat back down into it's holding clips. Some models have two bolts, on on each side, holding the lower part of the back seat cushion in place. You need to pop out the bottom seat section to access. Removal of the rear arm rests makes this much easier.
package tray liljohn442 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 04-19-2011 04:07 PM
69 Lemans package tray repair Jays69 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 03-02-2009 01:13 PM
putting together a H/C package for my 05, your thoughts needed... OMENOUS Engine Discussions 0 09-24-2008 10:41 PM
package tray blues blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 07-10-2008 05:03 PM
Package tray sheet metal blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-27-2008 10:35 AM
