Newbie here with a pontiac 400 question - Pontiac GTO Forum
post #1 of 8 (permalink) Old 01-11-2016, 01:27 PM Thread Starter
I just finished building a mild 400 to go in a 1970 Lemans pro touring project. My question is can you run the heater hose into a water port on the intake instead of the cylinder head? I am using all steel braided line and there is not much clearance between the vac advance and the heater hose. Will make timing adjustment difficult. Thanks in advance
Tafc18 is offline
post #2 of 8 (permalink) Old 01-11-2016, 04:26 PM
komodo's Avatar
That's a good question, I'm running mine (heater hose) from the back of the passenger side head (1970 400 #12 heads and intake).
komodo is offline
post #3 of 8 (permalink) Old 01-12-2016, 06:58 AM Thread Starter
I want to run my return from the heater core into the water port in the intake. Seems like a good way to run it, however I see that no one else is doing it. Why??
Tafc18 is offline
post #4 of 8 (permalink) Old 01-22-2016, 11:27 AM
frenchGOAT's Avatar
A bit off topic but I am curious, what does your mild 400 build look like ? What kind of work, cams intake etc.
frenchGOAT is offline
post #5 of 8 (permalink) Old 01-24-2016, 06:35 PM
I thought the return from the heater core was to the pump/timing cover and the supply was from the head?
I'd have concerns though that the flow entering where it wasn't designed to might cause cavitation and/or a restriction in normal coolant flow and could create hot spots in the engine.
BierManVA is offline
post #6 of 8 (permalink) Old 01-24-2016, 09:07 PM
67Twistytee's Avatar
Return is to the timing cover. The presumed "problem" with the design for the 400 is loss of a portion of coolant volume to the heater core that now cannot travel back through the head in the same way the drivers side does. This causes the passenger head to run hotter than the drivers side. It can be reduced some by using a restrictor in the short heater core hose from the rear head to the core. If you're not concerned about originality, some have also run and additional bypass hose from the rear head back to the crossover to reduce total flow to the heater core.
Cavitation issues typically occur in the pump itself if you have a small or shallow stamped impellar.
To TFAC18s question, the older 64 routing did take the heater core input from the crossover near the radiator inlet and outlet back to the timing cover. I suppose you could plug the rear cylinder head and try the routing you suggest. I see no reason why it shouldn't work.
Andy
'67 GTO/Signet Gold over Parchment/Pontiac Built
67Twistytee is offline
post #7 of 8 (permalink) Old 01-24-2016, 10:18 PM
Some 301's used a 90 degree fitting that was drove into the same round hole at the back of the head, same hole that the "nipple" type fitting was driven into.
If I was modifying the coolant route in a race application, it would utilize a Y type routing to the rear of both cylinder heads, no pipe plug on the drivers side head.
post #8 of 8 (permalink) Old 01-27-2016, 08:45 PM
Which is exactly what I did on my car. I've got two nipples (chortle) on the car, one at the rear of each cylinder head, Y'ed together.
Question on Pontiac 400 Blocks mrvandermey 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 03-18-2014 01:04 AM
67 pontiac 400 from gto gsregal86 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 11-25-2013 08:32 AM
What Oil to use for a Pontiac 400 67 GTO 1964-1974 Tempest, Lemans & GTO General Discussion 10 10-18-2013 12:22 AM
Timing on Pontiac 400 72luxlemans 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 3 02-25-2011 07:39 AM
400 Pontiac with six pack nicken Engine Discussions 6 11-10-2009 04:58 PM
