Nitrous Oxide anybody? - Pontiac GTO Forum
post #1 of 19 (permalink) Old 07-10-2013, 07:54 PM Thread Starter
Quoted: 361 Post(s)
Have many books and a ton of magazine articles on power additives from turbo's, superchargers, and nitrous Oxide.
I plan on using a 125-150 HP kit on my build, using forged rods/pistons because I am building for big HP to begin with, but know even cast pistons will be just fine in the 100 HP -125 HP kits.
Nitrous works best on low compression engines, 8.0-9.0 range. It really wakes them up. It would seem to make a lot of sense to me to have a mildly built street 400 CI 0r 455 CI, add the nitrous, and have an engine that will push into the 450-500 HP range with gobs of added torque, at a push of the button.
My question: Any of you have experiences using nitrous on your Pontiac? Again, see it used in magazine cars, but don't know of any actual first hand users with Pontiacs.
post #2 of 19 (permalink) Old 07-10-2013, 08:28 PM
BOOM!
Seriously though, have an adequate fuel system, do not skimp on wiring, run a hobbs switch on the fuel side, I wouldn't recommend a throttle activated kit, use a manual switch.
Why NOS though? Just build a healthy motor to begin with. You will get tired of filling bottles and it always seems to run out just when you want or need it. And it's like crack, addicting and you'll start to want more and more. Pretty soon you've got two plates and a fogger and you keep telling yourself that those hypereutectic pistons can take a lot of abuse.....
I've been there and went supercharged. Just sayin........
post #3 of 19 (permalink) Old 07-11-2013, 09:30 AM
Quoted: 98 Post(s)
No real experience with it, but what Alky says. I like power the old fashioned way, all motor and no snakeoil or steroids. I always considered Nitrous the cheater's way to make power.
post #4 of 19 (permalink) Old 07-11-2013, 02:57 PM
X3
Go turbo, twin turbo or Supercharger.
post #5 of 19 (permalink) Old 07-12-2013, 06:27 PM
Indetrucks's Avatar
Do it, YOLO
Indetrucks is offline
post #6 of 19 (permalink) Old 07-23-2013, 07:03 PM Thread Starter
Quoted: 361 Post(s)
Originally Posted by Rukee View Post
X3
Ok, sure. Why don't I just skip all the add-ons and go with a Pro-Stock Mountain motor? Obviously some here have deep pockets. I'm just a po boy maximizing fun and cost in a balancing act that suits my budget. Going lower compression so I can run the "cheap" gas. Running a tunnel ram(going to make it) with dual quads and velocity stacks because to me they look the best. I know, your all rolling your eyes, getting those body tremors, and the corners of your mouths are twitching.......'cause you want to say "No Way, It won't work, Your Nutts." Well, yes I am -nothing new there. HaHa. So don't even go there. Just trust me. HaHa Remember, in theory, Bumble Bees are not supposed to be able to fly. So, I'm just trying "my theory" on how I want to build my engine and not some one else's. Got a few trick's up my sleeve.
Simply wanted to get a couple of Pontiac owners viewpoints on their experiences -preferably street cars and not drag cars. I am not racing my car at the track or trying to best 1/4 mile times. Just looking to use it for what it is, a few seconds burst of power and not a 10 second pass through all 5 speeds.
Personally, if I had the cash, twin turbo would be my pick.
post #7 of 19 (permalink) Old 07-23-2013, 09:15 PM
Not bashin' Jim, just giving my opinion. I had a fast street car with NOS and it ended up burning to the ground do to my stupidity.
I just want to caution you on piecing together a setup on the cheap. And definitely have a fire extinguisher and a Hobbs switch on the fuel side. Back in "the day" when me and all my buddies had systems on our cars; every one of us had some sort of catastrophic failure on the juice.And the systems kept getting bigger and bigger. I've seen NOS backfires that literally blew carbs off the manifolds, bent rods and fried pistons.
So when you add it all up as far as a system, all the upgrades necessary to ensure your motor lives and the bottle refills a blower or turbo system isn't really that far off. I picked up my blower with the carbs for under $1K. They are out there.
And I'm definitely not a deep pockets guy, just a gear-head with some grease under his fingernails, some good buds, horsetrading skills and a knack for finding some deals.
post #8 of 19 (permalink) Old 07-23-2013, 09:22 PM
Nitrous can be a great power adder. So can twin turbos. Each require some careful consideration when utilized. Nitrous certainly is quick, easy and way cheaper than twin turbos. I would consult with the nitrous kit supplier and see what they recommend.
Stock cast pistons do not do well with detonation, low compression or not. A lean condition can cause detonation. You will need to spend some $$$ on a fuel system unless you are using a small shot of nitrous.
Not trying to be a wise ass here, but making horsepower takes stronger, well matched parts. Anyone can tack on a huge nitrous system, push the button and go. To keep the engine from going Kaboom and causing you to spend huge amounts of money. I'd talk to the supplier. I'd rather add 50 horsepower reliably than add 150 horsepower and run over engine parts......
mikea455 is offline
post #9 of 19 (permalink) Old 07-25-2013, 07:06 AM
It is your build....... I am with Alky on this one, all the way. My experience was almost identical, put a kit on and man -oh-man that stuff works, give it a lil more and then you want to rip down the road and you run out......bummer, then you want more pressure so you get a bottle warmer and an extra bottle.... and on and on.... then the BACKFIRE that blows the top of the motor part way through the deck lid and then you have melted aluminum manifold shards impregnated into the GLASS. Then just happy that the huge explosion did not do any serious bodily harm other than temporarily ringing in the ears..... long story short.... I would supercharge it, or just build it GOOD. It will cost much less than nos.......
fasterfiero is offline
post #10 of 19 (permalink) Old 07-25-2013, 09:00 AM
You say you're not going to race the car but tunnel rams are made for drag racing and perform like crap on the streets with no/hardly any low end performance. A dual plane is what you want for spirited light to light low end torque and you can get them in a dual 4bbl, just sayin....
Feds raid 17 Calif. auto stores for nitrous oxide ALKYGTO The Lounge 2 05-31-2013 11:34 AM
Nitrous Oxide Stang Eater Intake and Exhaust Discussions 15 11-20-2009 07:54 AM
Nitrous goatboy04 2004-2006 GTO General Discussion 4 09-21-2008 04:17 PM
Nitrous Help raphtime Engine Discussions 5 07-18-2007 08:22 PM
Nitrous???? pickinfights Service, Maintenance and Technical Discussion 5 10-08-2006 06:11 PM
