Is it normal for push rods to have spring? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-08-2015, 02:15 PM Thread Starter
EdR
I'm putting my engine back together and went to adjust the rockers and noticed the push rods can be pushed in about a half inch, just with some light pressure by hand, as if their on springs. They spring right back when released. I used comp cam hydraulic lifters. When I rotate the engine the valves all open and close so I know the rods are sitting on the lifters. Is it normal for them to spring like that? If it is how do I adjust the rockers?
EdR is offline
post #2 of 3 (permalink) Old 03-08-2015, 04:17 PM
Quoted: 364 Post(s)
Wild guess on this one. Did you install them dry? They simply might not have any oil inside of the lifters. I typically submerge each lifter in oil and them place a pushrod into the cup and pump it a few times to get oil inside. I would think this would build some resistance and you would not get what you are experiencing. I also do a fine adjust of them while the engine is running IF you are using the locking type aftermarket rocker arm nuts.
However, I did find this thread that details installing the lifters "dry" and it seems to be an approved method as well. adjusting hydraulic lifters with no oil? [Archive] - NastyZ28.com
post #3 of 3 (permalink) Old 03-08-2015, 04:36 PM Thread Starter
EdR
This is exactly what it is. Thank you!
EdR is offline
No oil coming up thru the push rods ??? jimmy328 1964-1974 Tempest, Lemans & GTO General Discussion 4 11-07-2014 10:30 AM
push rods and rocker arms Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 17 03-14-2011 10:39 AM
valve springs, push rods and rocker arms Richtenb Engine Discussions 5 10-31-2010 04:21 AM
Final Push xcmac26 1964-1974 Tempest, Lemans & GTO General Discussion 15 10-06-2009 07:45 AM
